Need help on putting a belt on an aiwa turntable
    Brigadier General:
  • 8,619 Answers
Hi
Please follow this :
1. Take the matt off.
2. Take the platter off (the turntable with the two square holes at each side)
3. Turn this (the platter) over and wrap the belt around the large cylinder on the underside (no fiddlin with the inner mechanics)
4. replace platter
5. Rotate platter until one of the holes reveals the brass motor pulley.
6. Pull the belt over the motor pulley
7. Replace matt
Please check this is a generic video that applies to almost all turntables including yours that will show how to install the belt and a few other things.
Replace Turntable Belt
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on May 25, 2009
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
Put belt back
I attached a guide for helping you to replace a turntable belt.
Jul 07, 2013 | Aiwa PX-E860 Turntable
My turntable willnot spin aiwa px-860
Sounds to me like the belt has snapped. To replace, lift the platter off the table. On the inside of the platter you will notice a second ring, or rim. the belt should be put on the outside of the second rim while the platter is still in your hands. Next, slide back the platter and look for the spindle running the platter through one of the big holes in the platter. Slip the belt onto the spindle and turn with your hand to make sure it runs freely. Hope this helpsmicmor100.jpg
Jan 17, 2011 | Aiwa PX-E860 Turntable
I have an Aiwa PX-E80K turntable. Whenever I start the turntable, the tonearm raises moves across, drops on the outer edge of the vinyl then then turntable stops. The belt is still attached. Anyone able to...
I suspect the belt is that slack that when the arm weight is on the record, the belt slips around the shaft of the motor. Does it start up again when the arm is lifted up? If it does then you need a new belt.
Jan 09, 2011 | Aiwa Audio Players & Recorders
AIWA PE860U got the platter of and the belt was
if it's falling off regularly, you will need to replace it soon.
Apr 18, 2010 | Aiwa PX-E860 Turntable
The drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on
Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
Dec 14, 2009 | Aiwa PX-E860 Turntable
Have Aiwa CX-NA555 with 3-CD turntable. CD's won't play because belt that connects motor to screw-drive on turntable is broken. Where can I get part number and/or replacement belt? Tx.
i have an aiwa cx-na555, the turn table want work the belt is good however when the table slides in it does not raise the turntablr motor into position because the yrllow does not unlock the turntable, its as though it is out of time, ineed help
Dec 07, 2009 | Aiwa Audio Players & Recorders
TURNTABLE SPEED TOO SLOW. IS THERE ANY WAY TO ADJUST IT.
The liely cause of the slow speed problem is the belt. Your turntable is belt driven, like components in your car's engine compartment. As the belt ages, it can begin to slip. Replacement of the belt will probably restore the speed once again. The PX-E860 turntable has been discontinued. There are parts, such as the belt, that are still available. How much longer these parts will be available for remains unknown. If you like the the turntable, you should consider purchasing several belts as the next time you need one, they may not be available or may cost much more.
One source for replacement belts (there may be many others, ie: eBay):
http://www.elexatelier.com/aiwa.htm
You might also need a manual to direct you as to how to go about changing the belt. The manual is a free (after registering) download below:
http://www.retrevo.com/support/Aiwa-PX-E860-Turntables-manual/id/1077bh126/t/2/
Oct 05, 2009 | Aiwa PX-E860 Turntable
Turntable help
http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things.
Sep 20, 2008 | Aiwa PX-E860 Turntable
 Grubhead
Grubhead
