Refrigerators
Problem for Refrigerators
Generic problem for all Refrigerators
Freezer very cold fridge warm.
By jeffbrenning on May 25, 2009
I've got a GE Side by Side, I removed the defrost heaters to order new ones, and plugged the unit back in (yes I expect the freezer to frost up) the freezer quickly got cold but the fridge is still very warm (after two days running) how does the fridge circulate the air like the freezers fan does? everything worked fine before the defrost unit started shorting out. I connot see the the defrost heaters helping to make the fridge cold.
Comments:
May 25, 2009
- Fan is running great, I tried plugging it in so it pushes into the freezer or pulls air out of the freezer but neither effects the fridge. (I don't know which way it is supposed to go)
May 25, 2009
- But the fan only moves the air around the Freezer, I can see the opening at the top with a door (presently open) and a hole at the bottom between the freezer and fridge but no air is really flowing between the two and the holes are not clogged. Is there a second fan to move air in the fridge?
Solution #1
posted on May 25, 2009
Not Rated)
jmgldsmth
Rank: Guru
Rating: 86%, 462 votes
the freezer circulates air through the refrigerator by using a fan every 24 hours the defrost timer comes on the compressor goes off and, the machine defrosts if your mullion defrost heaters are getting hot
and, staying hot you have miss-wired your defrost timer
Comments:
May 25, 2009
- usually there are two fans if there is a bulkhead the fan should blow from the freezer into the refrigerator box
Was this helpful?
Yes
No
Solution #2
Not Rated)
tborn6
Rank: Guru
Rating: 85%, 328 votes
does the fan come on if not then the fan delay is bad
Comments:
May 25, 2009
- does it come on right away or is there a delay?
Was this helpful?
Yes
No
Popular Solutions for Refrigerators
Questions and Unsolved Problems for Refrigerators
Answer
I am thinking of buying a used 2005 GE side by side fridge model GSS25XSRCSS. Any experience good... (More)
Answer
the samsung four door quattro refrigerator
Answer
hello Mike. i have a Smeg Fab32 too, about 6-7 years. the fridge is not working. both compressors... (More)
Answer
rga60 hotpoint freezer mase a bang noise when i opened the door now it's not working? the light was... (More)
Answer
I have a refrigerator model MFD2561HES and there has been a buzzing noise for the past day. I need... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
