Question about GE Spacemaker JVM1640SJ Microwave Oven
REPLACING DOOR HANDLE
HOW DOES ONE REPLACE DOOR HANDLE WB15X10069 ON A MICRO WAVE/CONVECTION OVEN? THE TABS ARE STILL IN THE OVEN DOOR.
  • GE Master
  • 9,047 Answers
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on May 26, 2009
How to replace the door handle on a whirlpool MH2155XPQ micro wave
The screws that hold on the handle are inside the door assembly. Here is the way its done but its not for the average person. On the inside of the door is a plastic frame all the way around the door. It is held in place by plastic tabs. You have to gently pry off that frame with something like a putty knife or small screw driver. If you are not careful you end up breaking off some of the tabs. Once that frame is off you should have access to the 2 screws holding on the handle. Remove screws---replace handle---and push plastic frame back on.
Jun 26, 2015 | Whirlpool MH1150XM Convection/Microwave...
How do I replace parts on the door of the GE Profile Advantium 120 Microwave
the door will come apart so you can screw it in from the inside its pretty easy just lay it out so you dont lose parts same with the clips they shoud either snap in when you have door apart or screw it in its just time consuming and terious work buy its do able
May 01, 2012 | GE Profile Advantium 120 Wall Oven
When micro wave oven is in use, I can feel air coming from the door. is it leaking micro waves?
Not likely if the door seals are intact, clean, and the door is latched. The pin-holed screen that you can see through stops the microwave energy. Hope this helps!
Jan 25, 2011 | LG LMH1017 Convection Microwave Oven
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
How do i replace a broken over the range micro wave door handle
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The door handle is a simple repair that can be done with the door in place, or removed. And, you do not have to uninstall the oven if this is an over the range model.
It would help, however, to know what brand and model microwave oven you are referring to. All ovens are not designed the same and are assembled in different ways. What I have provided you with is the basic information that applies to most microwave ovens. If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you
Apr 24, 2010 | Microwave Ovens
LG LMVM2055ST Microwave. went completely dead, completely
I replaced outer door with key panel on my LG MICRO MODEL LMVM2055ST which solved my problem but when I went to put the handle back on it did not fit. The tophole in new panel for the handle is round and the old one is rectangle. LG says I have right part can not help me.A new handle comes rectangle shape. What now?
Mar 15, 2010 | LG LMVM1935 Convection/Microwave Oven
Need to replace handle on micro wave can not
I HAVE A GE PROFILE SPACESAVER 2.0 OVER THE RANGE MICRO WAVE, CRACKED HANDLE, WOULD LIKE TO KNOW HOW TO REMOVE HANDLE AND INSTALL NEW ONE.
Dec 18, 2009 | Jenn-Air M439 Microwave Oven
How to replace the door handle on a mod. MH 1170XSY-0 mico wave
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Jul 09, 2009 | Whirlpool MH1170XS Microwave Oven
Replace handle on adeantium sca1001fss01
you have to take the door off and pop out the plastic molding around interior of door. You can do this by sliding a screwdriver around the edge until you can get your fingers in. Be careful because there are some small plastic tabs that will break very easily. Next, remove screws on the backing of the door. There are similar tabs holding the backing on even after the screws are removed. I used a pair of insulated pliers and used the handle to pry the tabs back. Be careful because the tabs will break easily. Then the screw handle is exposed. Pretty easy huh?!!!! I just comleted this process and am looking for a handle. I am sure I will have to super glue some areas since I broke the tabs off.
Good luck
Jun 01, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
567 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
