Question about Roper RT14DKX Top Freezer Refrigerator
The electronic fan, in the freezer, does not work.
    Problem Solver:
  • 9 Answers
Refrigerator section which is on the top is not cooling, however the lower freezer section is working and making ice. Fan in refrigerator section does not seem to be working. Maytag mod#mbf2254HEW
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. The fan should spin freely when you spin it. You can check the fan plug for voltage to see if it's getting power with the door switch pushed in. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
Dec 26, 2010 | Maytag Refrigerators
Freezer side works fine. Fridge side not as cold as should be. Fan is working on freezer side
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jun 16, 2010 | Kenmore 44109 / 44102 Side by Side...
Whirlpool fridge not blowing cold air but freezer
May 28, 2010 | Refrigerators
Kenmore trio 596.76522500 fridge not cooling freezer works
if you need to assist the evaporator fan motor you need to replace. this should fix your problem.
Oct 13, 2009 | Kenmore Refrigerators
Bottom Freezer Refrigerator: Freezer is working, fridge is not
Oct 01, 2009 | Refrigerators
2 yr old kenmore refrigerator with bottom freezer. Refrigerator not cooling. Freezer is
This unit has an electronic speed control on the condensor fan which controls the cooling in the refrigerator unit. The electronic control failed which allowed all items to work as intended just without a high enough fan speed to cool the refer unit.
Aug 23, 2009 | Kenmore Refrigerators
Top fridge not working
The Refrigerator receives all of its cold air from the freezer. There is a Fan that forces this air from the freezer into the Frig. If you don't hear the fan running or can feel airflow, then your fan is not working. Some newer units have electronic circuit boards that control fan operation. Sometimes the problem is the fan and other times the entire computer board needs replaced.
Nov 21, 2008 | Zanussi Refrigerators
My Kenmore Trio refrigerator (#596.76502500) is not working. The temp is 76degrees. The freezer seems to be working fine. I have switched it off at the circuit breaker and restarted it after 10 min. The...
The fan that blows cold air from the freezer to cool the refrigerator is not working. If your a little handy with tools its an easy fix. Its located in the freezer. Open your freezer door take off the steel panel at the back of the inside of the freezer. After you remove the panel you will see the fan the blows the cold air up to the Frig. A quick trip to a local appliance store for a new fan with do the trick. Put in the new fan 100% fixed even better than new because the orginal part is defective Kenmore should have recalled them. I have the same frig and its been perfect since I repaced my failed fan.
Aug 04, 2008 | Kenmore Refrigerators
Freezer
If the freezer is in defrost then the freezer fan should be off. Only on the electronic will the freezer fan come on in defrost but the freezer door has to be held open for 3 min before the fan comes on
Jun 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Roper RT14DKX Top Freezer Refrigerator Logo
150 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
