Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Light turns on by itself
If I turn the light off using button on keypad,within a minute or two it 'll come right back on by itself.Had to pull bulbs off unit to keep from coming on.Craftsman 1/2 hp 13 years old all original equipment.
    President:
  • 3,197 Answers
You have a bad wall control.
Posted on May 26, 2009
Brake light and right turn signal come on at same time
You put in the wrong bulb and it's feeding back.
Feb 02, 2018 | 2003 Jeep Liberty
How to replace rear turn signal bulb 99 park avenue
Replacing a front turn signal bulb is easy, as I just did my own. On the front driver's side, look at the wheel well splash panel and you'll see one plastic pin. Use a claw hammer and pull the pin out. Now just pull the plastic splash panel out of your way.
Look behind the front bumper and you'll see the light fixture. The top left wire and & bulb socket is right there. Give the socket a 1/4 turn to the left and you have access to replacing the bulb which is a 194, available at any parts store, 2 for $5.00.
Jul 07, 2012 | 1999 Buick Park Avenue
Burner turns itself off on KESA907
Most likely the switch that controls that burner is the problem and needs replacing
Nov 11, 2017 | KitchenAid KESA907PSS Electric Kitchen...
Replace a 2004 headlight light bulb
The Head Light Bulb,can be removed from the back of the headlight under the hood,you'll have limited space to work,but reach in to the back of the assembly, you'll feel a couple wires that go to the bulb socket,you'll need to pull back a rubber boot over the bulb socket,and very easy turn the whole socket until it releases from a wire hold down,and pull it out,remove bulb from wiring socket and replace it just the reverse way you took it out, DON'T touch the Bulb its self with your fingers. Ck the number on the Bulb replace it with a Compatable Bulb.
Jan 05, 2012 | 2004 Lexus ES 330
How do I change my turn signal rear bulb? What tools will I need?
Welcome to Fixya!
Here's the procedure on how to replace the signal light.
1. Open the trunk
2. If you have a convenience net, remove it.
3. remove the top plastic wingnut that the convenience net hooks to.
4. pull back trunk liner
5. remove the 2 plastic wing nuts found under the trunk liner
6. carefully pull the tail light assembly from the vehicle
7. squeeze the tab on the socket (turn signal lamp in the inboard socket)
8. turn socket counter-clockwise
9. pull out the socket
10. pull lamp straight out
11. push in new bulb
12. reverse steps to reinstall lamp assembly
Note: replacing left and right turn signal bulbs takes about 5 minutes.
Thank you for using Fixya!
Dec 06, 2010 | 2001 Buick Regal
How do i change the rear brake light in a toyota corolla 2003
  • Pop the trunk.
  • Look at the backside of the tail light area – it’s wide open. Turn the affected light bulb socket to the left. It’ll take some force, but you won’t break it.
  • Once it unlocks, you can pull the light bulb out.
  • Push the new bulb in.
  • Put the socket back into its place by pushing it in, then turning to the right. It’ll lock back into place.
  • Test the brake light to make sure it works.
  • Jun 22, 2010 | 2003 Toyota Corolla
    How do I get to the back tail light to replace it. I removed the cover where the light is, however I can not get to the light bulb itself.
    Tail light replacement is not as hard as it seems.
    Tools needed:flat head screwdriver and a deep 5/32 socket(a pair of pliers will work).
    Step 1: open trunk and pull back truck liner at tail light.There is a small button clip on liner.Use screwdriver to pop up the center of button clip,pull clip out of hole.
    Step 2:You will see a black wire attached to the body of car with 2 white clips.Use screwdriver to pop clips off of studs.
    Step 3:Remove the nuts from the studs and pull tail light assembly straight back away from car.The outer side of the light just snaps in and out of place.
    Step 4:Turn light socket counter clockwise 1/3 turn and pull out.
    Step 5:Pull bad bulb straight out and replace.Reverse steps to reassemble.
    Mar 22, 2010 | 2007 Nissan Sentra 2.0 SL Sedan
    Blinker issues
    These are two seperate issues:
    the light staying on solid green indicates a bulb blown at either the front or rear, this could also be a bad ground connection but usually is a bulb issue. If you replace the bulb, be sure to use bulb grease to seal our moisture.
    As far as the signal arm returning to neutral and cancelling the signal, that is controlled by a part within the steering wheel itself, and could just be worn. It's a Plastic/Nylon piece that pushes the signal arm manually when you turn the steering wheel sufficiently. That would be a dealer part, or something purchased from a salvage vehicle.
    good luck
    Mar 12, 2010 | 1997 Buick LeSabre
    Panasonic pt 50dl45 shuts off buy itself
    You probably have a lot of dust inside.
    Open the back panel and vacuum.
    Also use compressed air to blow into the components. Do not blow into the fan on the right as it will get the dust inside the lamp housing.
    Oct 15, 2008 | Panasonic PT-50DL54 50" Rear Projection...
    Craftsman garage door keypad
    The blinking on your keypad simply means that a code of some sort was sent. Whether it be the right on or not. Lets try to reprogram the unit. Press the colored learn button on the motor head and then within 30 seconds enter in the 4 digit code followed by the up/down action button. The light bulb should flash to let you know it has been accepted. Wait 5 minutes and try. If it does not work replace the keypad.
    Jul 17, 2008 | Sears Craftsman LiftMaster Chamberlain...
    Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
    168 people viewed this question
    Top Sears Building Materials Experts
    Glenn Mayer
    Glenn Mayer
    Mike
    Are you a Sears Building Material Expert? Answer questions, earn points and help others
