Question about Dishwashers
What does LE mean on the control panel
LE came up on our control panel while we were operating our dishwasher and I looked at the trouble shootong information and it was not there. Could you tell me what it means
    Problem Solver:
  • 14 Answers
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Posted on May 25, 2009
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
Remedy:
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
LE on the display panel
LE is a motor error.
Possible Causes: Wiring connections, Impeller is locked, Rotor is locked, and or the Blade is locked.
Remedy: Repair the wiring issue, Remove the item stopping the turning of the motor/rotor/blade, Replace the sump assembly, or Replace the main Power Control Board.
If your motor was making in knocking sound before this error, then your issue is probably the motor sump assembly. Just replace the sump assembly and your problem is resolved. You can get these from EBAY for about $105 with free shipping.
Good luck.
Jul 23, 2010 | LG LDF6810ST Stainless Steel Built-in...
Have trouble code LE?
wash motor is bad or the harness from the upper control to the motor has shorted out if you take the front panel off and look at the harness it runs from the top of the door doen often the wires fix themselfs into the coating on the door and melt agianst it that dishwasher can get pretty hot but it causes the wires to short out often if you pull them out of the black tar it will simple break in your hand make sure power is off to unit you can put a **** connector ther if this is your probablem but it is recommend you replace the harness and the door panel
Jun 02, 2010 | LG LDF6920 24 in. Built-in Dishwasher
LE on display
I just had my LG dishwasher fixed. I told the repair man that LE light was comming on. Even over the phone the repairman said its probably broken wires on the door. Me being in construction for years looked around the door for wires. Anyway the repairman took off 6 screws around the door, took the cover off. You will see about 50 wires taped together. He pulled them aside and visually checked them one by one. Sure enough two were broken in two. He twisted them together put tape and he was gone. $87.50 Still Working!
Mar 25, 2010 | LG LDF6810ST Stainless Steel Built-in...
"LE" Error Code appears on control panel
LE is a motor error Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked. REMEDY Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB.
Sep 24, 2009 | LG 24" Built-In Dishwasher - Black
Asko 1876 dishwasher soap flap opens as soon as power on.
I don't know about the control panel - I am having trouble with mine too, but in regard to the soap dispenser -- don't use it anymore. Just buy those little tablets. That is what the secretary at the repair shop told me when I had a problem and that's been fine.
Sep 24, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Le code on ldf6810bb lg dishwasher
The LE error code can mean that the impeller is damaged or there is some debris blocking the the sump area underneath the filter or the wash motor has failed. In that order.
Remove the spray arm and filter (9 phillips screws) - inspect impeller for damage, with flashlight, look everywhere for debris (watch out for broken glass!) Reassemble and test.
If problems continue, schedule as service call focused on the wash pump/motor.
Good Luck!
Apr 06, 2009 | LG LDF6810 Built-in Dishwasher
Model No- LD-12AW2 LE Error showing what does this mean
LE error code means that there is a problem with the motor.  One thing to check is to remove the front door panel and check the wiring harness to see if there are any broken wires.  If there is, repair the wire connections and see if the dishwasher returns to normal.  If not, then the motor assembly will need to be replaced.
Apr 20, 2008 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
140 people viewed this question
Top Dishwashers Experts
