Question about E-Machines eMachines Desktop PC
Won't boot up
My compaq presario won't bootup.oxc000014c is status.
    Scholar:
  • 69 Answers
Put original Operating System CD into drive, boot computer from CD and start reinstalling system. When you get to screen that says you can press "R" to repair the Operating system, press "R" and see if it can fix the system. Once it's running, be sure to check for Malware (use Malwarebytes) and viruses (use Vipre-rescue) - and get a good registry cleaner (Cleanmypc) and clean up the registry. If repairing the OS doesn't work, then you'll probably have to format and re-install everything. Being a Compaq, watch the screen for a "Restore" function, and follow the prompts.
My first method will not lose you date, the second one will. Restoration will format the drive and you'll lose everything.
Good luck.
Posted on May 25, 2009
Compaq presario won't boot caps lock blinking power button on
hi
maybe you have change the keyboard , it is failure
Sep 05, 2012 | Compaq Presario Notebook
Compaq presario beeps 3 times, won't boot
3 Beeps is usually a RAM issue. Try re-seating your RAM in their slots and rebooting.
Feb 05, 2012 | HP Compaq Presario SR5262NX Desktop PC
It won;t bootup
Is your monitor plugged in and turned on? There may also be a bad connection between your computer and monitor. Failing that, your motherboard may be bad.
Jul 10, 2010 | Compaq Presario 5000 PC Desktop
Compaq Presario S5300NX (DM174A#ABA) PC Desktop: Compaq Presario Dekstop: CPU Fan error on bootup. ...
The fan has a third wire, that is used to tell the uProcessor that it is spinning and in some cases how fast.
Replace the fan and that should fix it. Spares form many suppliers on ebay
May 18, 2010 | HP Compaq Presario S5300NX (DM174A#ABA) PC...
Wont boot up,black screen.message on screen says,invalid partitio
When you power up your computer, the system examines the master partition table to determine what volume to use to boot up the operating system, and detected invalid information within it. This is caused by an incorrect or missing active partition.
To resolve this issue, consider the following steps:
  • Boot up the computer with a Microsoft Windows 98 boot up disk or Windows XP recovery console. Select the correct bootup device before you do that.
  • At the DOS command prompt, type in: fdisk
  • Question - Do you wish to enlarge large disk support (Y/N) ?
  • Enter: Y
  • Now to check for active partition, enter: 2
  • Look under the Status column. The active partition is usually assigned to the drive which contains your operating system.
  • If there's no active partition set, enter the number of the partition to make active
This must solve your problem.
Apr 15, 2010 | HP Compaq Presario 2200 Notebook
HP DL380, drive 1 and 2 lights are not on, but 3 is. Can I swap new drives in those spots and it write automaticaly. Or is there and easy fix, I checked cables and connections, reset hardrives and powered...
Boot from HP Diagnostic Media (SmartStart CD)and check the status of Array.....or harddrives...
If showing any failed status or not supported..
Replace drives to check if new drives show status...
It could be because of Drives not intialise for Array..
Boot to Array Configuration Utility...during bootup and go to Intialise disks....
Use them
Oct 05, 2009 | HP Compaq ProLiant DL380 G4 Server
Installing windows vista on compaq presario 750 computer stops responding during installation now can't boot or startup
Vista installations inbult drive format tool is not so good, and causes errors, so i recomment u format the drive with some linux live cd's or some other bootup type partition tools. Then do a clean install. The problem should be solved if u hav min system requirements for vista.
Mar 21, 2009 | HP Compaq Presario F750US
Pc won' t go pass the product name on start up.it does let you try the f1 buttons.
go to BIOS presing f10 on system starting and disable the bootup massages option..
Mar 01, 2009 | HP Compaq Presario SR1630NX PC Desktop
HP Compaq Presario V6000T
what you need to do, is go into the Bios. usually F2 at setup.
Or esc or delete. you have to press a few times at bootup.
Once in the bios screen, find the page where you can change the boot sequence. it,s probably set to boot from HDD( hard disk ) set it to boot from CD/DVD first then FDD Or HDD second.
when you save and exit, it will boot from the dvd drive, this will give you access, to use the cd drive first.
then re-install your operating system.
Mike @ compurepair.
Apr 04, 2008 | HP Compaq Presario V6000T Notebook
E-Machines eMachines Desktop PC Logo
97 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
