Question about Philips CCA132AT 13 in. Combo
Stationary horizontal lines
Horizontal lines on philips cca132at01
  • 1 more comment
  • ptreuhaft357 May 25, 2009
    so it's not something i can fix with codes
    I have a picture, the lines are like notebook paper a bit wider at the bottom than the top.
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Can you describe the lines, pattern, how many, is there a picture, or just lines?
  • 585 Answers
The problem could be a broken solder joint or crack in the circuit board. Either of those conditions would respond to a slap on the side, not to fix just to tell what the problem is. It could also be interfrence, does it show using another channel or video source? An internal power supply failure like an open capacitor could cause this as well.
Posted on May 25, 2009
  • 700 Answers
If it a collapsed vertical or fold over commonly it a single horizontal line on the center of your tv. This is a vertical IC fault. Could be loose connection on the board. Or the vertical IC itself is faulty. You can check also minor component within the circuit. Commonly you can still sounds from the program it is tune in.
If you are not inclined in electronics better to have it check by the expert.
  • Philips Master
  • 3,866 Answers
This is a flyback issue and it would need to be replaced. Aslo check the horizontal IC's for faults.
  • Grand Canyon Tech
    Grand Canyon Tech May 25, 2009
    No there is not code that would fix this problem
My tv will turn on but with white light line then shut off itself
If the line is horizontal (it is a vertical problem) If its a Vertical line (it a horizontal problem) So it could be just a bad solder joint or a component has failed in the horizontal or vertical section. Hope this is helpful.
Nov 28, 2009 | Philips Magnavox 27MS343S 27" TV
My sony LCD hdtv has a line thin white horizontal line about a third way down from the top of the scream. How can I solve this
If the line is stationary and a very fine line and affects the on screen display or menu you have a bad panel.
Nov 22, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Horizontal lines at the top of the t.v. screen.
you will have to find fault in vertical deflection try condencer replacement in that stage
Jul 11, 2009 | Philips 27PT6441 27" TV
Gray screen with horizontal lines accross it
sounds like you may have a bad ic it probley is a surface mount on the bottom of the board it could couse this problem would need to take to a shop to repair. The ic probley is numbered ic101 on board.
Mar 01, 2009 | Sanyo DS32224 TV
Black horizontal lines
Sounds as if you have a bad capacitor in the horizontal deflection or video circuitry. You can spot a bad capacitor in circuit with a ESR meter.Hope this helps.
Jan 16, 2008 | Mitsubishi TS-5545 55" Rear Projection...
Horizontal lines
http://home.tiscali.nl/m.majoor/tv__matchline_service_mode.htm Sounds like you need go this site, enter codes and re callibrate your TV to the settings. If this does not work - then sounds like you need tv repair man replace caps or solder bad joint. Miyan sung, former philips rep man, Korea.
Aug 29, 2006 | Philips 32PW6506 32" TV
Thjeres a problem with the screen voltage driver voltage capacitor or the crt is going bad. have the shop test the b+ on the crt board first off . then remove the crt board and see if the voltage comes up. If it does the capaicitor is bad as it can take the load. But remeber theres extremly hi Voltage inside these sets so its never a good idea to try to do this your self unless you have the training to deal with HI Voltage and the proper saftey and test equipment. Good Luck
Jun 21, 2006 | RCA F25655BC 25" TV
Philips CCA132AT 13 in. Combo Logo
227 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
