Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Water comes in but does not wash the dishes no pressure
Water comes in but it does not wash the dishesno pressure the soap does not even disolve
  • 48 Answers
It could be a few problems, first of all does the water circulate at all, if not then you most likely have one of two problems, it is either a plugged pump, or the washer arm in the bottom of the dishwasher is plugged, first take the arm loose by turning the big nut at the bottom of it loose and take it too the sink and wash it out as best you can......reinstall the arm, try the dishwasher, if it still does not work, then you have too remove the pump under the washer and clean it out, also you should be running a dishwasher cleaner every six months..........you can purchase this at any grocery store, walmart, kmart, in the dishwasher isle...........hope this helps.
Posted on May 25, 2009
    Problem Solver:
  • 9 Answers
Check the term of water intering the dishwasher, might not be the D/W.
My dishwasher does not wash the dishes, and all th...
Either:
  1. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller. Disassemble and clean pump if necessary.
  2. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
May 19, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Dishes not coming clean, film ring on glasses and dried grime on the utinsels. Have run through twice with vinegar, not sure what to try next. Checked basket/drain and it was not blocked just has a small...
That sounds more like a problem with your soap not disolving completly. Try these few simple things. First, run your hot tap at your sink until it gets hot, then start your dishwasher. What this will do is ensure that your "prewash" is using hot water.
The next thing, is you want to select the "heated wash" or "hi temp wash" option with a "normal wash" cycle. What the heated wash will do is ensure that during the main wash the water gets boosted to 140 degrees wich is the temperature that your soap breaks down at.
White film left on dishes is a classic indication that the soap has not disolved or broken down completly.
Oct 02, 2009 | Bosch Dishwashers
Soap is not disolving. Falls out of holder and stays on door and floor of washer.
Are dishes also not coming clean? Most likely, there is not enough water chruning in the tub to rinse soap out of cup during wash cycle. Sufficient wash action will wash the soap out of the cup and dissolve it in the water within a few seconds of the cup opening.
Most likely causes are:
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Hope this help. Good luck.
Sep 11, 2009 | Dishwashers
Soap does not disolve (licquid or pouches(. just
Make sure your spray arms are not clogged, large untensils/ pans hitting spray arm(s)??
Is the d/w filling with the proper amount of water?
If the above is ok, then you might have a clogged sump filter or weak main wash pump
Apr 29, 2009 | Dishwashers
OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Dec 04, 2008 | KitchenAid Dishwashers
Saop not disolving
Low water pressure. Caused by not enough water in machine (water valve or house water supply). Also could be pump screen is clogged up (bad chopper assembly) Also could be caused by spray arms themselves being clogged. (goes hand in hand with pump screen being clogged) These are the 3 most common problems i have seen and all could cause low water pressure in the machine. This is assuming the dispenser door is opening!
Apr 28, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dish soap not disolving
Is the water heating up? This may be the problem.
Apr 14, 2008 | Dishwashers
HElp Dishes not coming clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Dishes not clean
water valve under dishwasher that let the water come in is not opening all the way causing either low water level or no water to come into the dishwasher. with out the proper amout of water the soap cant be disolved. replace water val to solve problem
Nov 20, 2007 | Maytag 24 in. MDB6100A Built-in Dishwasher
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
678 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
