TV buzzes on bright/white picure
We have a JVC D series TV that is about 6 years old. Lately, it has started to hums loudly whenever the picture is bright/white or has white printing on it, such as in ads. When I turn to the TV guide, although I can still hear the commercial or tv show that was on, because the picture changes to a dark one (our guide is dark colours)the hum stops immediately. It always occurs in the same commercials in the same places and stops immediately if we go to guide. I'd hate to toss this puppy but if it isn't cost effective to fix it .... Any ideas?
  • 1 more comment
  • thesnowdenho May 25, 2009
    I guess checking the cable would be the first thing to try. That room was painted recently, maybe something got switched.
    If it isn't the cables, it sounds expensive!
    I checked the cables and I think they are all fine. What are the caps and can they or the tuner be replaced?
    If so, is it a high cost thing?
    Okay thanks, I thought it might mean capacitors. I will do some reading.
    thanks again.
  • 3,866 Answers
This is due to waer and tear meaning the caps in the tuner are waering out you may want to check the cable as well but its far more then that.
Posted on May 25, 2009
Loud humming or buzzing noise have picture but flashes all different colors resets and goes off after awhile good pic after that
The tv problems and causes are 100% is the tv colors wheel it is causes and the tv problems.The tv are having humming or loud buzzing noises sounds are the causes of the tv colors wheel going off and out control of it motor mount and spinning in at high RPM speed and different colors showing up or flahes of black and white color in the tv back ground.The tv colors wheel must have to be replace.Best hire a tv tech to do the replacement of the tv colors wheel,because have to take out many mechanicals parts before can even come to the tv colors wheel is self to replace it.
Aug 19, 2011 | Samsung HLP5067W Television
I have a 50" Samsung DLP about 6 years old. Like seagoat, My set is making a "buzzing/humming" sound. Just before it did that I heard a single "pop" sound. For the past week or so the picture has been...
Tv have a colors wheel,hearing a humming or buzzing noises or black&white picture flashes with the picture,the colors wheel is dead.Hire a tv tech. to replaced the colors wheel,it pretty hard to replaced the colors wheel,because have to have take out alots of machanical parts,before even can come to the colors wheel itself to replace it.
Oct 25, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Good Morning\r\n i have a JVC Interiart 29" Flat screen tv which is 8 years old which has started making a noise when switched on,a very loud humming noise and no picture for a couple of minutes then the...
That usually indicates a capacitor going out in the power section or flyback section of the board inside. Depending on your repair shop this can be a fairly cheap repair (or not). Get an estimate and know what a replacement tv is worth. Sometimes its cheaper to get a new one than repair the older tv. As well power problems can stress other parts so it might get fixed only to fail later.
Jun 14, 2010 | Televison & Video
Have picture, but no color and loud humming sound
the color wheel needs replacement. You can get a replacement color wheel at www.tvrepairworld.com
Oct 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
Apr 24, 2009 | Amana ASD2622HR Side by Side Refrigerator
TV Making a Loud Noise
this can happen with the flyback transformer's brightness which can be adjusted , also the power transformer can make humming or buzzing sounds which can't be adjusted , also this can happen with the picture tube or the CRT board failing , and sometimes chips with heat sinks or the IC's themselfs
Oct 07, 2008 | Symphonic ST420FF 20" TV
Jvc pd35b50bu no brightness
Hitachi 46F510 different channels are different brightness and to get them viewable I have to run the brightness so high that you can not see any text at all. Also all white areas are blasting white bright. Edges of the tv also seem darker. I am connected to a cable system.
Feb 28, 2008 | Televison & Video
My Sony tv CRT
If it's between 5-10 secs, that's normal. You will turn the tv on and hear a loud (buzz/hum) that is the picture tube firing up, once it's fired up, it has a few more seconds until your picture comes up fully. That is about 5-10 secs from pushing the power button.
If it's taking longer than that, your picture tube may be going out.
I had a 36XBR250 and it took about 10 secs to fire up and show a picture, and it was 5 1/2 years old.
Nov 25, 2007 | Televison & Video
Loud Buzzing Noise
Check filtr capacitor in power unit.
Check filter capacitor on supply to audio amp ic. or Amp ic itself is defective.
Gopali
Apr 23, 2007 | JVC AV-30W475 30" TV
Televison & Video Logo
262 people viewed this question
Top Televison & Video Experts
