I do not have a solution to the problem. However, I am having the same problem. This morning the Actiontec GT704WG power and ethernet lights were rapidly flashing. The modem was non-functional. I could not even connect to the modem through the browser to see if I could find a problem.
The problem lasted a couple of hours. Then all of a sudden the modem started working again. I won't be able to tell if the problem recurs until I restart the modem. And if the problem does occur again, I won't be able to connect to the internet.
SYSTEM RESET If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may turn on the TV again. Changes you made the last time the TV was On before you used the SYSTEM RESET button may be lost, however, the changes you made previously are not lost. POWER/TIMER Indicator The green light is a multi-function indicator. This light will flash rapidly for about one minute each time the TV is plugged into the wall electrical outlet, when power is restored after a power failure, or using the SYSTEM RESET button. Do not attempt to turn on the TV again during this period. Wait for the flashing to stop and the light to turn off, before attempting to turn the TV on. While the TV is powered on, the light illuminates steadily. If the TV has been programmed to turn on automatically using the Timer feature,
You will have to be a bit more clear on which lights on which model of modem is flashing rapidly.
Usually, as long as the internet works, the flashing lights are there to show that the modem is functioning properly and is currently sending packets, transmitting data, etc.
The rapid flashing of the battery light indicates a shorted cell in the battery pack. This causes the machine to overheat when it is trying to charge the battery. Removing the battery will stop the falshing for a bit but as soon as the machine tried to charge the battery again you will have the same issue. If this is not corrected soon it can damage the charging circuit in the laptop and then you have to replace the main board in the unit as well as the battery. if the unit is under warranty get them to send a new battery. If not check Ebay for a replacement one. I hope this helps you and if it does please rank the solution.
