Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Front Load not draining
Front load Bosch wash machine seems to be not draining correctly... I can set the spin or drain cycle on and it occasionally can drain but not every time. suggestions.....
    Problem Solver:
  • 18 Answers
Sounds like a blockage. First port of call. Check where the drain hose goes into the sink trap of your Laundry Trough. Here in Australia we connect the drain hose into the sink trap. Most of the time if the hole drilled into the sink trap is not large enough it can create an obstruction in the waterflow out of the machine. Lint and stuff can build up and partially and at times fully block the exit into the trap. Try this first.
If that appears fine you should remove the drain in the front bottom of the machine. Use a bath towel to absorb the wter that exits as you unscrew the round plug in the bootom of the machine. If the plug wont unscrew or only partially unscrews you will need to call a technician to remove the drain pump and unblock things.
Goodluck. Let me know how it goes.
Regards Sam
Posted on Sep 20, 2009
SOURCE: washing machine will not spin
MY WASHER WANT SPIN AT ALL
Posted on Nov 15, 2008
  • 135 Answers
SOURCE: bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
Posted on Nov 22, 2008
  • 26 Answers
SOURCE: whirlpool duet hf error
This error code indicates a water supply problem.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
Are the water inlet hoses kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details; find them by entering your model number in the search tool below.
fl_hot_cold_back_of_washer.jpg Is the water pressure less than 10 psi?
If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Are you using HE High Efficiency detergent?
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds can prevent the washer from detecting the incoming water.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
See also: Why HE High Efficiency detergent is required.
Are you using flood-preventing inlet hoses that can shut off the water to the washer?
These hoses have a valve inside that will close if the water pressure is higher than two gallons per minute; this will shut off the water to the washer. If one of these hoses becomes loose, the water flow through the hose will increase and close the valve inside the hose, which will shut off water to the washer to prevent a possible leak or flood. If the hose is not loose, try taking the hoses back to the store for a replacement set.
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTES:
  • On some washers, when the washer is started for the first time after this error code, it will begin to drain. You will not be able to pause or cancel the cycle for about 8 minutes while it drains. This is normal.
  • If the error remains on the display, and all of the other conditions above have been checked, call for service.
Posted on Dec 20, 2008
barkencoa
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
  • 713 Answers
SOURCE: won't drain in last cycle
Hi just read your posting.Now can you confirm the model number please.Please ;look underneath the machine to the front right and you should see a pump with a red or black fan attached.Turn this fan clockwise and anticlockwise a few times to hopefully loosen the pump if it is jammed.If the fan turns freely then put it back on its feet and start a spin cycle to see if it drains the water.Please reply with additional information on the questions and to tell me if you have the pump with the fan or if it is not draining or if it still is not draining.
Posted on Jul 08, 2010
Bosch wfl 2060 washing machine makes a funny rattling sound when it should be spinning or draining. why
Check the filter behind the flap (Bottom right of kickplate) souns like you have a coin or other foreign object in the pump.
Feb 18, 2013 | Bosch Axxis WFL 2060 Front Load Washer
HAV2360 Maytag does not drain before spinning. Drain cycle seems not to engage.
Unlike Whirlpol and Kenmore washers Maytag Washers drain and spin at the same time.
Apr 10, 2011 | Maytag HAV3460AWW Top Load Washer
Bosh neither spin nor drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
My washing machine is not draining properly, even when I set it to the drain and spin cycle.
heatman101
Sep 17, 2010 | Maytag EPIC MFW9700S Front Load Washer
Does not spin dry after rinse cycle; it drains, but the clothes are not spun dry
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 18, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Won't do final spin
Washing Machine2_bing.gif does not Pump or Spin
Front Load Washing Machine not draining and or not spinning
heatman101
May 14, 2010 | Frigidaire ATF6000ES Front Load Washer
NOT DRAINING WELL ON SPIN CYCLE
Clean the filter/pump bottom r/h side..
Apr 06, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washing machine won't spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
heatman101
Oct 26, 2008 | Bosch WFK 2401
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
321 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
