I have a whirlpool washing machine that won't stop filling, it drains and washes perfectly, if I turn the tap off and manually turn the knob to wash it will drain and wash as normal, but if I leave it to wash normal it just keeps filling up and floods the laundry. Thanks
  • sagiandpisc May 25, 2009
    Hi Vic
    Thanks heaps for your help!!
    The model number is 67sc8255EQ1.
    Thanks Again
    Linda
    President:
  • 1,136 Answers
Hi, The inlet valve has gone bad. If you would get me a model #, I could look up the part# and instruct you on how to change it.
Thanks
Vic
Posted on May 25, 2009
  • Victor
    Victor May 25, 2009
    Linda, That model # is not showing up for me. Could I ask you to check it again, please.
    Here are instructions for the more popular Whirlppol washers:
    Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
    Now the cabinet will lift off the frame and you can set it aside.
    Once the cabinet is removed, take the hoses off of the inlet valve and remove the two screws holding the valve in. Notice where the two wire harnesses plug in. Take the hose of the fill side of the valve and put it on the new valve. Plug the wires back on valve and fasten the valve back on the wall.
    Let me know so I can get you through this.
    Vic
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Washing machine won't fill. i filled it by hand with water, it won't agitate either, only spins.
The inlet solenoid is probably bad. And it won't agitate unless it fills and stops filling automatically.
May 17, 2012 | Whirlpool Washing Machines
Whirlpool washer model LSR5232LQ0 won't drain. just stops. is there way to cause drain?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 22, 2011 | Whirlpool Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My machine wont drain
check you lid switch.open and close the cove see if you hear a clicking noise.
Nov 03, 2008 | Whirlpool LSR5132PQ Top Load Washer
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
