Question about Sanyo SV-M305U Electric Shaver
Foil for Sanyo Shaver SV-M305U
I need to buy the foilfor Sanyo shaver SV-M305U.
For one year sanyo Brazil says that they still waiting for part importing.
Can you help me to find out where can I find this foil?
Thanks,
Norton
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
I have a Braun 7570 and it is marvelous! I replace foil and cutter every year. This time after replacing it the shaver did not cut my hair. Battery still gets full charge. What is the problem?
Most likely, the 'drive unit' is bad. The drive unit is a component that consists of the swivel frame that the head snaps onto and the motor. Excessive noise while the shaver is running is also a major sign that this part is bad.
Unfortunately, Braun no longer provides these type of replacement parts for any of their shavers. You may end up needing to replace the unit.
Since you apparently like that model and you have spare shaver heads for it, you might want to consider a compatible model as a replacement. shaveroutlet.com has a new model that uses the same foils and cutters as your 7570. You can see it at the link below
http://shaveroutlet.com/shavers/foil-shavers/braun-series-1-195s-mens-cordless-shaver.html
Feb 19, 2014 | Braun Syncro 7570 Electric Shaver
Series 3 - 340, my father wants replacement foil & cutter, where can I order one from please.
Braun makes two distinctly different models, both with called seroes 3-340. You will need the type number as written on the shaver to properly identify the correct foil and cutter for his shaver. Both types are available at shaveroutlet.com. See the two links below. You will need to use the type number of his shaver to select the correct one of these two
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-foil-and-cutter-p-141.html
http://shaveroutlet.com/shaver-replacement-parts/braun-series-3-shaver-foil-and-cutter-head-cassette-32s32b-p-835.html
Jan 11, 2011 | Braun Health & Beauty
Where should i can buy ms5100 shaver blades
remington SP-96 replacement screen foil and cutter heads for electric shaver remington ms5100 blades replacement parts.
Mar 17, 2010 | Remington MS-5100 Electric Shaver
Won't turn on unless we pop the top foil up..then we have to push it back in place.
this is an odd problem. i have two thoughts of what the problem may be.
1. the thin trimmer blade between the foils may be dented causing extra friction that is sufficient enough to keep the shaver from starting from a stopped position. If this is the case, you will need to buy a new foil and cutter set. These are available at shaveroutlet.com. to check this, remove the foil from the shaver. look on the underside and you will see where this center cutters fits to the drive arm on the shaver. move this back and forth with your fingers. if it has a dent or imperfection, you should be able to feel it snag as you move it back and forth
2. your shaver motor brushes may be worn. if this is the case, i would expect that when you do get the shaver running, it is not running at full speed. the part needed to repair this problem is linked below
http://shaveroutlet.com/braun-7000-series-syncro-motor-drive-unit-p-110.html
Jan 17, 2010 | Braun Syncro 7526 Electric Shaver
Where can i take my braun shaver for service? needs a foil/blade replacement
you can buy replacement cutter blocks and foils at walmart...about 50 bucks.
Mar 28, 2009 | Braun 360° Complete 8985 Electric Shaver
Remington es1000
The Remington ES-1000 was probably the best slot-head shaver ever made by Remington. I cannot believe that the market demand was so low as to prompt a cancellation of production. I believe that the production run was limited to about 4 years or so. I have 8 of these shavers and keep a couple old Remington slot heads around as well. The ES-1000 was not perfect. The batteries were way too small and stressed so battery life was poor.You could not buy individual blades as you could with past Remington slot-head units.Also, the edge of the head was too exposed and sharp and when used for body shaving would tend to cut the skin.Slot-head shavers are superior for body shaving and for skin that is suseptible to shaving bumps.They are also great for young men that are prone to ingrown hairs.My guess is that the Norelco 3 head has taken it's place. Those shavers actually use 3 small slot heads. Rumor has it that shavers.com is trying to have a new slot head manufactured in Asia.
Dec 05, 2007 | Remington ES-1000 Electric Shaver
Foil for my electric shaver?
I need to change my Hitachi Phase 4 shaver foil of RM-8670B urgently please. Where can I buy it?
Oct 18, 2007 | Hitachi RM 2500 Electric Shaver
Sanyo SV-M305U Electric Shaver Logo
366 people viewed this question
Top Sanyo Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Sanyo Health and Beauty Expert? Answer questions, earn points and help others
