Question about Garden
My mower will steer left but when i try to steer right just click
And does not turn to right. tired of trying to mow my lawn in a left turn circle. It a 13.5 sears craftsman model no. 917.258501
  • Dwain Pippen May 11, 2010
    By not turning right, do you mean the steering wheel turns but the wheels don't?
  • 284 Answers
Sounds like your sector gear and pinion are at fault go to sears.com to parts and enter your mod# you gave. if this is the problem could be labor intensive to repair
Posted on May 25, 2009
Troy Bilt Lawn Tractor won't turn left - still turns right
hi, mam i want to solve this prolem try contact or text this number 0927642929 / ( 032) 5127262
Sep 11, 2012 | Troy Bilt 175HP Manual 42" Riding Mower
My son was mowing, with our cub cadet 2166, and ran the left front tire into a fence and now the steering wheel wont work. You can turn it and it feels really loose but it isn't connecting to the
Check the two main gears. One at the end of the steering shaft and the other that it contacts. Some brands are adjustable where the large gear is held on by a bolt and an excentric which allows you to move the large gear closer to the smaller gear. This may have been knocked out of place or the gear(s) stripped. Here is a basic diagram of the parts.
Cub Cadet 2166 steering parts
May 19, 2012 | Cub Cadet Garden
Steering, The right front axle and tire lean in as if I were turning the steering wheel in the left direction but the left axle and tire remain straight. If I turn sharp to the left the right tire turns...
1) there are also bushings which hold the axle assembly into the front cross member, take a look at those.
2) while you are at it, replace the front wheel bearings on both sides
Aug 07, 2011 | John Deere Garden
I have a 2 year old Cub Cadet and I find it very hard to steer the wheels during mowing.
First grease the the axles and all steering components associated with steering, there should be grease fittings where you can pump grease into, then make sure your tires are all filled to proper psi. Good Luck...
May 06, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Cannot have blades engauged when in reverse mower stalls
You are right, the mower has a disconnect for the pto when you try to mow in reverse. You need to turn the key to the mow in reverse position, and now you can mow going backwards.
Hope this helps, Matt
Dec 11, 2010 | Toro LX466 22HP Lawn Tractor 13RT61RH244
Electric pto will not engage the mowing deck. stopped working while mowing.
had a similar problem. The engine mount bolt that grounded the PTO black ground wire was loose- causing the pto to work erratically. To see this bolt (13mm i think) you will have to lie on your back and look under the machine. It is above the front steering arm of the right tire. If the wire is dangling you will need a new bolt. Thanks for the previous posts ;)
Aug 01, 2010 | John Deere Pto Clutch For Stx38 And Stx46...
Craftsman Lawn tractor - When turning to the left the Left front wheel turns much farther then the right front wheel does on a hard right turn. Almost perpendicular to the tractor. Busings are brand new....
I've noticed this on other Craftsman and MTD mowers. The ones with the one main steering rod from the steering wheel to the left wheel and a connecting rod from the left wheel to the right wheel. I think that since we are advised to mow in a counter-clockwise direction, they design the mowers to turn tighter towards the left. It's in the design just like you suspected.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
406 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
