Question about Refrigerators
2000 Kenmore Refrigerator 10659502993 I am looking for used door handles in white.
I have 2000 Kenmore Refrigerator 10659502993 I am looking for used door handles in white. I need two of them.Do you know where I can buy used doors handles for this model?
  • 78 Answers
Please buy new one! please
Posted on May 25, 2009
The white plastic(?) full length door handles OUTSIDE the refrig are turning yellow on my white, side by side refrig. What can I purchase or use to re-whiten them and make them look clean and white again?
That yellow coloring is most likely a result of the white paint coming off, and the yellow plastic color showing underneath. Other than painting them with a good paint, which you would have to ask a paint expert for the proper type, my suggestion is to replace the handles altogether.
Oct 13, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Handle is loose on refrigerator,how to tighten the handle
There should be some small Allen (Hex) screws on each bottom side of the handle. Just use a Allen wrench and tighten it up.
Jun 06, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
On my Kenmore Elite #106.56683501 the refrigerator door is loose
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.)
Sep 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Removing refrigerator door handles
You might try checking to see if the screw head is actually on the handle, but hidden by the handles cover. Look at the side and see if you notice a seam. This can be pried open and the screw head will be seen.
Feb 23, 2009 | Kenmore Refrigerators
Door handle is loose
If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
Feb 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Want to reverse door swing on Kenmore refrigerator model # 795
Actually, I have a Kenmore 795 model with the top door and bottom drawer freezer. I just tried this, based on "guru's" advice. Unfortuately, though the TOP hinge on this model is reversible, the bottom hinge is NOT. I got it all apart before I discovered this problem. Also you might want to note that the 7/16th wrench is too big for my bolts and the 3/8ths is too small. I had to use an adjustable wrench...maybe they are metric.
An allen wrench will get the handles off for you. You will find little ports for it if you look carefully.
Nov 27, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Door handles loose
i have a whirlpool conquest side by side and had loose handles,couldn't figure out.but then i grabbed handle and push in and up,handles slide off you can then tighten bolts then slide it back on.hope this helps.n
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Replace door
The fridge should have come with a card that looks like a credit card to remove the handles.  There are directions in the manual on how to do this.  If you don't have the card then use a sturdy card like a drivers license.
Oct 26, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Loose freezer door handle
Maytag uses two types of door handle mounts. first look at the bottom side of door handle to see if there are tiny set screws. If there is you might just have to tighten them with an allen wrench. If it doesn't you need to grasp the handle firmly and pull it towards your left, sometimes they can be a little stubburn and require a light wrap with a rubber mallet. This will remove the handle. In this case there will be a clip inside the handle end, check to see if it is bent or if the handle itself is cracked, although I have seen some where the handle mount has become loose and that can be tighted by turning clockwise.
Jul 04, 2007 | Maytag MBF2556HEW / MBF2556HEB /...
Refrigerators Logo
441 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
