Question about Belkin (F5D7633UK4A) Wireless Router
Belkin f5d7633-4 wireless g modem/router
We have recently upgraded or internet package and until the upgrade the router was working fine. now when it tries to log in the adsl light flashes then goes solid the the net light will flash red then green then the adsl light will go out. Occasionally both lights remain green for 30 - 40 seconds then the adsl light goes out then the internet light goes out. I have tried resetting as suggested by belkin however no success. natuarally the zyxel modem supplied by the provider works fine on the same settings.
the system log says " received valid isp from server" then the next line will say "adsl link down".
I have tried to give as much info as possible if any would like more then please ask and I will try to forward
Richard
  • uae81 Dec 27, 2007
    i have exactly the same problem with the same modem/router..
    after the internet speed upgrade the belkin's modem could not connect to internet..
    i called the isp and asked them if they change any settings and they did not change anything..
    im now connected with the isp's usb modem and the internet is perfect..
Has anyone got a spare belkin f5d7633-4 cd pls : )
Posted on Sep 13, 2008
Hi again
the problem was fixed with a new belkin N1 wireless modem/router
Posted on Dec 28, 2007
    President:
  • 2,961 Answers
When you upgraded did any settings from your isp change like passwords or usenames that your router may not be registering at your isp's server, or the line speed that you are now getting is not suported by the router.
type 192.168.2.1 in your web browser and check the connection settings.
Posted on Oct 21, 2007
I recently upgraded to a Belkin N wireless router. A Belkin Tech person helped me configure it at start up . But, It randomly disconnects, I unplug the router and plug back in and it works fine. What can I...
Open RSP by typing 192.168.2.1 on the Address Bar of internet Explorer
On the Left side click Channel and SSiD underneath Wireless
Change the Wireless Channel into 11 or 9
And if it is not working you may need to update the firmware of the router from www.belkin.com/support
Also make sure that there are no devices such as the base of a cordless Phone or a Microwave Oven is placed next to the router or the computer (its because it will cause a lot of interference )
Jan 07, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
My Belkin N1 router can't seem to establish connection with the cable modem - the router light flashes and connects but as the internet light flashes it loses the router light again. It is still allowing...
the modem is working fine. the connection might be dropping from the router side.
You can try to upgrade the Firmware of the router.
reduce the MTU on the router. If it is on 1500 the reduce it to 1400.
Click Here from more info about routers
Oct 31, 2009 | Belkin (F5D8231-4) Wireless Router...
My router drops connection when I try to add security
did you try to upgrade teh firmware of the router ? that could be a probable solution . Also try to change the channels in the router. Make it to 6 or 11. Sometimes that could help
Thanks Ranjit
Sep 24, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin wireless G+ MIMO ADSL2 + modem routerF5D9630
You need to find out what settings need to be changed in the router to communicate to the new modem. Etisalat should have some type of instructions on how to configure it...Does the IP address get obtained automatically or is it manually configured. Does the modem require authentication..like a password. Did they replace the modem or just upgrade the system? You may just ahve to reset the modem and router to get reconnection. Most routers use the IP address of 192.168.0.1 or 192.168.1.1 to get to the router settings control panel. Just enter one of these addresses on internet explorer and a screen should ask for a password. The default password is usually ADMIN but consult the routers manual for instructions. Once you are in the router control manual you can configure the router to work with the new system.
Sep 08, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin wireless G router-2.4Ghz-802.11g ,i,m not getting the internet conection via router .pls help or give me tel no to contact u..i've been using the router for more than a year now and there was no...
Go to the Belkin support section at their website: http://www.belkin.com/support/
Look for your model router and download the "firmware" upgrade for it. Once you go install the up to date firmware try to give the router a reset. Hopefully doing all that will get the router working again and you connecting to the Internet.
Aug 16, 2008 | Belkin Computers & Internet
GotomyPC Intermittent connection
had same prob. 3 wired an 1 wireless . wireless would not conn. an others lose connection . after cable upgrade it was in router upgrade changed settings in router i had to call maker of comps an get them to reset ip adds took almost 3 hours to get them all working again they will do a remote access help by useing your ip threw your internet company hope this helps
Aug 07, 2008 | Belkin (F5D5231-4) Router
Belkin wireless
the red light means u havent got a connection if u have installed properly try upgrading the firmware the problem might be the routers
http://www.belkin.com/support/product/?lid=en&pid=F5D9230-4&scid=221
Dec 09, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Router - Network works for 5 minutes than everything loses internet capability.
hi,
           This issue usally occurs when the router is able to save the data stored or in  other words the Router id not able to AUTHENTICATE,  but as you already got a new router and you have already done the fireware upgradation of the router. we can also upgrade the firmware of your speedstream modem.
plz do these following steps ,( plz disconect the router from the computer and modem completly while doing the steps )
The Efficient 5260 modems that can be upgraded are as follows:
Look on the label on the bottom of your modem. It should read:
SpeedStream 5260 Ethernet ADSL Modem
Part Number: 060-5660-00x (where x=any number)
Revision: any (all revisions seem to work)
If your part number reads anything else, your modem is most likely not upgradable.
For those curious, 5660 models 003 and earlier do NOT support G.Lite ADSL, only DMT. If you are buying a 5260 or 5660 model secondhand, and your DSL ISP uses G.Lite DSL, it would be a good idea to check with the person selling you the DSL modem.
UPDATE: As of 5660 Firmware v2.3.0(2) and later all 5660 including 5260/5660 hybrids support G.Lite ADSL. It pays to use the latest Firmware.
PLZ REPLY IF THIS HELPS, I WILL TRY TO FIND OUT THE RESOLUTION FOR THIS ISSUE
REGARDS.
Gunjan ';';';';';';';
Oct 18, 2007 | Belkin (F5D8231-4) Wireless Router...
Belkin (F5D7633UK4A) Wireless Router Logo
432 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
