Question about Toshiba CF32G50 32" TV
No picture/sound with cable
Picture/sound would suddenly disappear - leaving only static... for a while, jiggling the coax cable (into the tv) would restore things, but now I cannot get anything.
Another tv plugged into the same cable connection works fine.
    Genius:
  • 1,694 Answers
Probable tuner as indicated, part # EL933L4
 List price 85..00 PTS rebuild only.......shop for best price....T.
Posted on Oct 22, 2007
  • Vista Electronics Oct 22, 2007
    By the way, you can bypass the tuner problem by using the
    A/V  outputs from a source box to the TV A/V inputs.....T.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
  • as per your statement it is quite clear that picture & sound use to disappear & cable worka for other tv
  • it clearly means that
  •  the socket where you connect cable might be loose or defectivr.
  • loose connection or print break near tuner & tuner itself.
  • loose contact or print break near VIF section supply or any components loose.
  • hope this will help
  • good luck
  • 21 Answers
Well tuners are being made smaller (and there is more cold solder in some points due to heat) so i would look up a new tuner for that tv...and if you know how to solder ,do it yourself it will be cheaper
Posted on Oct 21, 2007
Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Oct 03, 2008 | Panasonic CT-36HL43 36" TV
Mitsubishi rear projection no picture and static sound
I assume you are using a cable input, such as a box or the main Cable line connected directly to the TV. examine the main Cable Coax, look at the copper wire that sticks out from the connecter, make sure it is long enough, if its to short, gently pull it with a long nose plier until it reaches the rim of the connector. Sometimes when connecting the coax to a source, the copper wire in the coax is to short to make contact, and as a result you get no signal. Hope this solved your problem.
Jul 03, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Long power up time, wavy "static" lines, and red/orange problems
part of it sounds like your coax cable is not connecting properly. pull it out and make sure the pin at both ends of the coax cable is straight if bent replace coax cable.
Dec 28, 2007 | Hitachi 32UDX10S 32" TV
Pic problem
Quasar TV SP3232. Picture disappears but comes back by striking the TV . The sound keeps coming. Perhaps something is loose
Dec 23, 2007 | Quasar SP-3235 32" TV
Hitachi 57G500a no picture but has sound
Picture int disappears leaving snow on screen
Resolder the Xtal in the tuner
No picture
Replace IC (TDA8385J)
Sound but no picture
Check the LOT cable for short circuit
Nov 24, 2007 | Hitachi 57G500 57" TV
Female coax connector in tv bad?
Did the cable person take a reading on the signal level at the cable outlet on the wall and did the cable person check the TV setting to make sure they are correct. TV could be set on the wrong channel also.
Nov 08, 2007 | Televison & Video
RCA 25GT511 - fuzzy picture slight static sound; wiggle coax rear mount temp resolve
There might be a bad (loose) connection in the RF isolator or the tuner (both are silver boxes. Try to unplug the coax and bend the RCA tabs in so that the connection gets firmly made when reconnected. This may help. If it does not The connector may have to be replaced.
Aug 08, 2007 | RCA 32V550T 32" TV
Flickering of screen (comes and goes) and weird DVD/reception problems
Depending on how old this set is, there might be a bad Hyper board bad. good Luck
Jun 29, 2007 | Toshiba 43H70 43" Rear Projection...
Black comes across right side of screen
Sounds like you've got whats called a cold solder connection somewhere in the horizontal width control circuit or a connection in the sweep section. Should'nt be two expensive but unless you have had some soldering and troubleshooting experience I would leave this on to the pros. Good Luck
Jun 02, 2006 | JVC AV-36D502 36" TV
Televison & Video Logo
90 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
