Question about LG WM-2277HW Front Load Washer
How do I get to the pump on an LG washer? WM2277cw
I think the pum has something stuck in it.
I drained the filter etc. Now I need to replace the pump. How do I go in?
  • Jamiepe Oct 20, 2007
    I found out. First of all A penny was able to find its way through the filter and into the pump system. I am not amused.
    I tipped th unit onto one side.
    Took. off the bottom unit drawer
    From beneatht eh unit, there is access to the pump.
    I undid all clamps ( I think there are 3 clamps) to each hose connecting to the pumps.
    Unscrewed the screws to the outside face place of the filter (on the face of the machine)
    Undid the wires attached to the pump system and took it out.
    Unscrewed each pump from the entire unit that cam out (there are 2 pumps).
    Inside one, there was a penny.
    saved myself $400 service call :)
    LG, you suck!
Inside my pump were a whole bunch of sock :I
Posted on Jan 09, 2008
Washer will not drain. Filter was removed and cleaned. Washer makes humming noise
Most likely there is something stuck in drain pump open the drain pump hose and check if something is stuck there.
Aug 22, 2014 | Washing Machines
Need manual for whirlpool front load sport duet model wfw8600sr00
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged / kinked
Unplug washer/disconnect power
Check electrical connections to pump and make sure pump runs, check drain pump filter for strings,sand etc., plug in washer. If this don't work dismantle pump carefully to check if anything is clogging it. If the electrical side of pump is faulty this can easily be replaced, it is normally not repaired.
Washer parts can be found on this site.
Mar 04, 2013 | Washing Machines
Can I get to the drain pump or does the washer need to be torn apart? I cleaned out the drain plug- full of sand, filter clean, but I can't see the actual drain pump to see if something might be
You can get to the drain filter without need for disassembling.The filter access is located behind the protective trim at the lower front side of the machine. Remove the trim and rotate the filter cap anticlockwise. Be prepared to collect the water that will flow through the filter. After cleaning the filter perform operations in reverse order to reassemble. Disconnect power before starting.
The pump is located at the bottom of the machine, behind the filter. Accessing the pump requires disassembling.
Diagrams for WM-2077 are available here.
Apr 21, 2012 | LG WM-2077C Front Load Washer
My ZWD1680W stoped half way through a cycle flashed up E20 i draind i t tryed to spin got half way through and went of no power at all NOW
It still seems that something is stuck in the pump causing the machine to do nothing check the filter and pump again whilst the filter is out get a torch and look inside the end of the filter housing,now put the control to spin or drain and see if the pump blade is spinning if not then there is either something stuck in the pump or the pump motor is faulty and needs replacing.
Good luck.
May 03, 2010 | Zanussi ZWD1680W Front Load Washer / Dryer
Clear filter
If this is a Kenmore Elite or Whirlpool Duet series FRONT LOADER, the filter you are referring to is the drain trap. The followiong link explains how to access and clean the drain pump reservoir:
If you check the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, as well, and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage these small drain pumps. If an error is present, it is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
Replacements can be purchased at any of the following websites:
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER (located around the door opening) and let me know. I hope this helps you.
Apr 19, 2010 | Kenmore Elite 45986 Front Load Washer
Does not drain. makes horrible grinding noise when trying to drain
you probably have something stuck in the pump
it is a very easy repair actually
pull out the machine and unplug it
remove the back panal two screws, and remove thae back panal
you will se the pump on the bottom of the machine with tow hoses and two wires
grab some towels and disconnect the hoses and wires
turn the pum 90 degrees it should pop out
inspect the pump
as well as the sump hose,
that is the hose that goes from the tub to the pump
hope this helps
Oct 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from bottom, lots of suds.
Thanks for using FixYa. This may happen due one or more than one of these issues with your washer--
Probably there is something(coins, socks, dirt, debris, etc) stuck inside the drain filter of your washer. You'll need to check the drain filter. To access the drain filter. To check the drain pump follow these steps:
Unplug the washer to completely disconnect electrical power.Remove the bottom front service panel as shown in the first image below.
Also check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
This issue can also be due to clogged drain pump or drain filter, due to which the hose have developed leak. This will cause suds
Please rate the solution if you find it useful and helpful.
Sep 22, 2009 | GE Washing Machines
E20, slow to drain frigidaire atf7000fs
probably has something stuck in the electric drain pump happens alot on frigidaire washers it is accessable after removing front lower acess panel tilt washer back after pulling it from the wall the drain pump will be just right of center at the front use a pan to catch any water that will come out you can either remove the 2 drain hoses to clear obstruction or you can unscrew pump motor from pump body
Good Luck!!
Jul 24, 2009 | Frigidaire Affinity ATF6000F Front Load...
Asko D3120 I have resolved the problem of pum always running by tilting the dishwasher but now I have a new problem of the pump not draining the water in the bottom of the dishwasher. I thought it was...
In the bottom where the filter are, you can see a yellow 'thing'. Remove this and stick one finger in an try to rotate the pump wing. Try to remove particals that is blocking the pump.
Or there is something in the drain hose. Try to drain the machine by holding the drain hose over bucket. If it drain here, then the problem is under the sink.
Jul 17, 2009 | Asko 24 in. D3120 Dishwasher
Error E2
It is drain pum error. Possible solution:
• Clean the debris filter.
• Make sure the drainage hose is installed correctly.
If wont help you need to look in drain pump/wiring
More information about error codes here:
Good Luck
Jan 08, 2009 | Washing Machines
LG WM-2277HW Front Load Washer Logo
307 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
