Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
How to attach the upholstry cleaners
I need to know how to attach the upholstery cleaner
    Problem Solver:
  • 15 Answers
Easliy download the manual at Hoover.com.
The hose attached in the front of the unit on the clear front panel. Lift up the center cap and attached the hose. Then attache the supply hose to the side of steam vac for your solution.
Posted on May 25, 2009
How do you attach the upholstry attachment to your hoover steamvac
The hose hooks into the dirt bucket on the front where a clear plastic block sets. Put the hose in that slot and then hook the tube for the water at the top of the hood.
Nov 27, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
How do I attach the hose for upholstry cleaning?
Without the exact Hoover model number, all I can do is give you this general reference:
http://www.hoover.com/pdfs/manuals/F5857955.pdf
That should easily point you in the right direction.
Oct 06, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Leaks when trying to use upholstry cleaner!
This is a common problem for these units, and is easily fixed.
Bad connection:
You may need to push harder on the coupling when attaching it to the machine
A leaky Valve
Manytimes the Valve you connect to can bust or crack where you cannot see it.
Remove the hood and inspect valve. (six screws on underside)
Leaky hose
The hoses that run to the Valve you connect to can come loose or crack.
Remove the hood and inspect hoses. (six screws on underside)
This machine may be leaking the whole time you use it, and you my just not be noticing.
If you are in a northern climate, freezing machines in garages or cars is the most common cause.
Jun 04, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I need yo find out hoe to use the upholstry attachment. Ilost my
I'm not quite sure where the attachment plugs in but, I did find an owner's manual for this Hoover online.
http://www.hoover.com/pdfs/manuals/F5918900.pdf
I hope that helps. Good luck!
May 25, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam carpet and upholstry cleaner
I have a model F6211. On mine you have to remove the hose caddy and the door is under it.
Hope it helps.
Oct 11, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
I cant find my manuel for my steam cleaner and I want to use the uphostery cleaner dont know how to hook it up can you help me?
In front at the bottom thiers is a peice mine is square pull it up and out, now take the top of the tank lid off. now slide your upholstery attachment in that place where you pulled out the sqare. the open end facing up, now put the tank lid back on every thing should work .your welcome ttsgma01
Sep 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac Clean Surge
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=407245
Posted by just a brat on Feb 22, 2008
I can not seem to get the attachment for the upholstery cleaner to operate what am i doing wrong????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The attachment works on the suction from the Hoover Steam Vac and it’s either a straight suction tool or a revolving brush, check the front of the machine to see if the is a switch to turn on and odd, also before you attach the upholstery tool check the end of the hose for suction, it may be that your upholstery tool may be clogged or the brushes are not spinning and a part may be broken. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Feb 22, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Using upholstery attachment on the hoover spin scrup heated cleaner
I had the same problem. Instead of wasting time/energy I could use cleaning the furniture, I decide to look online for a manual instead. I hope this helps. It helped me!! http://hoover.com/pdfs/manuals/F5914900.pdf Good Luck !!
Sep 08, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
293 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
