Question about HP Pavilion dv6000z Notebook
I want to install web cam to my dv6000 hp pavilion
I want to know the most compatible brand of webcam to support vista i had the uk-407 cam but i lost the driver, is it possible to install it or is it compatible to my laptop? in case how would i install it?
there are cases when i open my laptop there instances that some portion of the screen in tiny squares appearance, is it just normal? but it is also disappears after a minute or 2.
There are also instances that i have to put the virus protection in pause before i can access my e mails which i can not when it is on.Pls. advise me what to do best thanks and regards Bernie
  •  Andrew Smith
    Andrew Smith May 11, 2010
    I need the full product number and name:
    Example:
    HP DV2000 as in HP DV2112TU
  • Lewis Fulkerson
    Lewis Fulkerson May 11, 2010
    I've always been partial to Logitech equipment, and I know they make a vista compatible Cam.
    Are the squares images or something else?
    Sounds like your Anti-Virus is set to being too secure. I would need to know what you're using in the AV and whether you're using Windows firewall or a third party brand. Anti-Virus software should not affect your email downloads unless there's a problem with system compatibility or the AV software itself.
I have a HP Pavilion dv6000 and the webcam does not work , i also tried everything still i couldn't use my web cam
did you try update correct drivers and reboot system?drivers is here -
http://www.hp.com/united-states/products/dv6000.html
Nov 15, 2012 | HP Pavilion dv6000z Notebook
Hp pavilion web cam dv6000 not working in vista home premium
It is possible that you may have not installed the webcam driver for it. Knowing windows it needs a driver for just about everything. Go to hp.com and go to support/drivers and type in your model number for your machine and download the driver for it. This should fix your problem. Let me know if this helps by ranking me, jeff from fixya
Jun 24, 2011 | HP Computers & Internet
I could not find my web cam in the computer pavilion ho dv6000 with vista sp , In the ddevice manager, there is not a image device
I have a dv6000 labtop. You should have an icon in your desktop that says "HP Webcam". If not, search for the program (click on windows sign, then go to "Find").
Apr 29, 2010 | HP Pavilion dv6452se PC Notebook
NEED A SITE FOR FREE DOWNLOAD SOFTVER-hp pavilion6000 integrated webcam
CLICK THE LINK BELOW AND DOWNLOAD AND INSTALL THE DRIVER
WEB-CAM DRIVER LINK
Scroll down the page and check for HP 1.3 MegaPixel (MP) Webcam Software Drivers
and install them...
Here's the link for HP WEBSITE where u can choose the model of your HP LAPTOP and then download the driver as well...
CLICK HERE FOR HP WEBSITE LINK
May 30, 2009 | HP Computers & Internet
How to operate the web cam
You may install this Webcam Driver for HP Pavilion DV6258se Laptop. HP Webcam Driver also includes Firmware Upgrade.
Driver Version: 1.00.11A
File Size: 8 Mbyte
OS Available: Windows Vista (32 Bit)
Link to download the driver -- http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-47244-1
Install the driver and check it.
It should work.
May 02, 2009 | HP Pavilion dv6000z Notebook
Y hp pavilion dv6000 webcam is not work mhay dont
ok ..I dont know exactly the problem that you have ...but I am link-ing you to the site where you will find all drivers for your model ...
so ..if you are running windows vista ....just go to control panel and uninstall the driver from remove programs ....
then you either install the new driver ...and after that run the wizard from add new hardware ...or it will prompt you for a driver after you uninstall the old one ...I dont know if its a build in or not web cam ...anyway the procedure is the same ...you will be also be prompt for restart
pav dv6000 drivers
Apr 08, 2009 | HP Pavilion dv6000z Notebook
Web cam(Yu cam) problem in HP Pavilion dv6000 notebook pc
go to web cam manufactures page and look for upgrade software and drivers.
Nov 10, 2008 | HP Pavilion dv6000z Notebook
Cant turn my built in webcam on??
This is known Webcam issue in DV6000 notebooks. To resolve or narrow down the issue, we have to check few things.
First open Device Manager.
Please follow these steps to open Device Manager:
1. Right Click on 'My Computer' icon on Desktop and choose Properties.
2. The System properties Window opens.
3. Click Hardware tab and then click the Device Manager button.
Expand + Imagining Devices and check if the HP Webcam is listed under it.
If Webcam is not listed there, then you have to contact HP to get the BIOS update.
If it is listed there, right click on it and select Disable. Again right click on it and select Enable.
Now open any applications like Quickplay and check if Webcam is working or not.
Please reply me if that won't resolve the issue, I can provide more work arounds
Aug 09, 2008 | HP Pavilion dv6000z Notebook
Wecam 1.3mp builtin for hp pavillion dv6000 found not working the day i bought the machine
Hi I have Hp pavillion dv6000. When am using yahoo msnger or msn ..the web cam not working. There is one message coming Your web cam is not connected. Please give me a solution for this....
Thanks
Simon
Jul 15, 2008 | Computers & Internet
HP Pavilion dv6000 Webcam problem
Download Quick play if you can i havent tride this before so i dont know if it will work hope this helps. =]
Feb 10, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
909 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
