I hsve a Brinks safe model 5050 my problem is that I forgot the combination of the digital panel and I have a key but the lock dosen't work and I can't get it open. And I lost the manual of the safe. How do I get into my safe?
You can't. This safe has a rotary combination lock and a failsafe key. The key is your insurance if you can't get in.
Call a local locksmith, for what will probably be destructive entry unless you have the serial number of the safe. A GOOD locksmith may also be able to impression a key for you. According to this you can get keys on proof of ownership.
Each Brinks 5059 safe has a different default combination, so to get the original combination you must either contact Honeywell (the parent company for Brinks safes) at 1-800-223-8566.
You need to send them a notarized letter showing safe ownership in order to get the master combination. When you call Honeywell, you will need to provide your safe's model number, the serial number (found on the right of the safe, near the model number), and your key number.
try taking it to a lock smith it will cost about 15.00 to 20.00 depending who you go to they will make a key or find the combination call a round . good luck
To bad you dismantled. Here is the turning sequence: General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
