Question about LG DU-62SY20D 62" Rear Projection HDTV
Resetting lamp hours
I have bought the new 52sz8r lamp for the DLP LG tv but the old lamp has not blown yet. What I want to know is the procedure for resetting the lamp hours so I can turn off the annoying "Lamp Life Over Error" meassage as well as be ready for when the lamp blows. I believe part of the process shows how many lamp hours I would have clocked up on the current lamp - is that correct?
  • LG Master
  • 3,866 Answers
No its not correct this error message is telling you your lamp is going out and pruchasing a new one will reset this otherwise you have to cut some wires! i would not recommend that!
Posted on May 25, 2009
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
I have a Samsung DLP HLS 5086 W that is shutting down after a couple of minutes. The color wheel and lamp were both replaced a little over a year ago. The lamp is a Phillips, and the color wheel is OEM. I...
Hope this helps:
Resetting the counter Once you have installed your OEM replacement lamp, resetting the counter is a very simple procedure:
• Begin with the TV powered off.
• Point your remote towards your TV.
• Press:
• Menu + 1 + 8 + 2 + Power.
• Your TV set should now say "Loading Factory".
• Browse down to "Option" then press Enter (or the right cursor button).
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterward!).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you're having difficulty with the ENTER button.
Resetting Your Samsung DLP Lamp Hour Meter Counter or Lamp Timer DLP Lamp...
Jan 14, 2015 | Samsung Televison & Video
On screen message "lamp life over, error!!, which
Hello John:
If you replace the DLP lamp out of your Zenith or LG, you will need to reset the counter...otherwise you may get an annoying reminder every few days if you're surpassed the predetermined hour mark.
To Reset:
Ensure the TV is powered on.
1) Press and HOLD the MENU button on the TV
2) Press and HOLD the MENU button on your REMOTE
(hold both these until the service menu pops up 5-10 secs max.)
3) Let go of the REMOTE button first, then release the button on the TV
4) Press and HOLD the ENTER (or OK) button on the TV
5) Press and HOLD the MUTE button on the REMOTE
(hold both until the LAMP LIFE HOURS appears on the screen)
6) Let go of the REMOTE button first, then release the button on the TV
We suggest writing your lamp hours on a piece of masking tape and taping it to the back the TV for future reference.
7) To reset the lamp counter, press SELECT (or the button in the middle of the direction arrow buttons). Hit SELECT a second time to confirm clearing the lamp counter
For certain models, you might have to tweak these steps slightly...
Mar 22, 2011 | LG Televison & Video
How do I reset the lamp life on my LG 52SZ8R.
hold the mute on the remote and press enter on the tv and it will come up in the menu for you to reset
Jul 08, 2009 | Televison & Video
How to reset the lamp timer count on a LG rear projection TV
1. Press the OK or enter button on the front panel and MUTE
button on the remote control simultaneously (About 5 seconds).
2. Press the VOLUME (>) button.
3. Press the OK or enter button.
Lamp time will be reset.
Jun 15, 2009 | LG Televison & Video
Installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Lg tv 52sz8r-tb new lamp installed, red lamp light still on
you need to reset your lamp hours timer. as far as i know this can only be done with the service remote
Dec 12, 2008 | Televison & Video
I have a LG 52SZ8R-TB DLP TV. I have recently had to replace the lamp. I ordered this through a certified LG repairer. Upon fitting the new lamp the TV appears to not be light enough. It is that dark I...
We had the same problem. One place changed the lamp but they couldnt work out why it was red and lots of shadows. Next mob said that it was the component so they replaced that. From the 28/4 till end of Oct, the TV has now switched itself off and wont come back on. Both places say its the lamp - however I cant see how in 6mths it would run out again. The people who replaced the lamp dont want to help, just said they will put in a new one at $521. This TV has cost us so far $1100 in repairs and it's only 3 yrs old. Not happy. The DVD recorder broke within the first year, the set top box broke in the 2nd yr and the surround system blew up (yes smoke appeared and we were lucky we were home) on the 13th month. Mind you our LG comp screen also shut down on the 13th month. Never again will I buy LG
Jul 14, 2008 | Televison & Video
Reseting lamp counter (LG)
Make sure the TV is on and:
1) Press and hold the Menu button on your TV SET
2) Press and hold the Menu button on your REMOTE CONTROL (at the same time)
3) Continue holding BOTH buttons down for 5 secconds or until the Service Menu pops up
4) Release the MENU button from your REMOTE CONTROL, then release the MENU button from the TV Set.
5) Press and hold ENTER (or OK) on the TV Set, then:
6) Press and hold MUTE on the REMOTE CONTROL (while still holding down the ENTER button on the TV SET
7) Holding both buttons down should lead to the Lamp Life Hours screen to pop up.
Release the MUTE button the REMOTE CONTROL, then release the ENTER (or OK) button on the TV Set.
9) Come back to this blog and post your HOURS on our site
10) Now press SELECT, then SELECT again to confirm the reset of the counter
** If the procedure above does not work swap steps 5 & 6.
** For a few special models (including 44SZ8D), you might have to change step 5 to:
5a) Press Enter on the TV Set to enter the Position Adjustment Screen
5b) Press and hold Enter on the TV Set (the TV should go back to the main Service Menu, continue holding Enter) and now also hold down the MUTE button on your REMOTE CONTROL. After about 5 seconds, your Lamp Life Counter should pop up.
Jun 30, 2008 | Televison & Video
Lg llp xg22 lamp reset
These instructions are taken from page 44 of the User Guide.
Turn the power off but keep pluged in. Press the buttons on the control panel in the sequence as below.
Press "Up Arrow", Press "Down Arrow", Press "Left Arrow", Press "Right Arrow", Press "Menu", Press "Enter".
Lamp time will be initialized
Aug 02, 2007 | LG LP XG2 Multimedia Projector
LG DU-62SY20D 62" Rear Projection HDTV Logo
611 people viewed this question
Computer Repairing
Computer Repairing
