Sony rear projection doesnt turn on
When I plug the set in I can hear it start to power up in the back and then something clicks and nothing happens. The red light blinks twice in the front.
  • 3,866 Answers
The power supply unit is bad and will need to be replaced. Aroung $150 just for the power supply unit if you can connect it yourself you can save over $200 bucks.
Posted on May 25, 2009
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
SD TECH
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Sony kp-65w5510 rear projection tv power button malfuction
Replace bulb and clean cooling fans of dust is the first thing to do. if that doesnt work might start checking capacitors on the power supply.
May 10, 2010 | Sony KP-65WS510 65" Rear Projection...
Tv will not turn on
If you hear a clicking noise that sounds like the ballast trying to power on the lamp, but nothing happens, the lamp may be faulty.You can go to http://www.discount-merchant.com/
to purchase a quality lamp.
Mar 26, 2010 | Hitachi 53UDX10B 53" Rear Projection...
My hitachi 43fwx20B does not turn on. When i plug it in i hear clicking in the back like it has power on the board but nothing happens when i press the power button
Replace both of your STK ICs they are big black ICs
will have Part number on them STK392-110s
if 110s upgrade to 150s! Call Mats Electronics for parts 1-800-628-1118 $9.95 each
Feb 15, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Nothing happens. power on,can hear click
I had the same problem, but I saw the events leading to it. I was watching TV, went to help the wife, heard a pop, came back to find the TV off. Turned it on, heard the same click you described. I believe you need a new bulb. Mine lasted around 2 years of heavy use. Bought two on ebay. Make sure to consult your manual for the particulars on the bulb.
Jan 07, 2009 | Sony KP-57WS500 57" Rear Projection...
HCJ552W 55' samsung rear project....won't turn on
dear friend you have a power supply problem, get one of those cheap meters and open the set, look for a blown fuse, if they are ok wich i doubt, you have to call the repairman.
good luck
caypianan@yahoo.com
Oct 23, 2008 | Samsung HCJ552W 55" Rear Projection...
When i press power nothing happens except the standby light just blinks and doesnt stop.
What is the make and model number of your set? I can help you but I need that info, So I know where to start.
Jan 23, 2008 | Televison & Video
SONY KP-61XBR38
Power supply . I would check for shorted Horizontal output transistor first then low voltage regulators. You will need some trouble shooting experience and a service manual for sure. You can get on at this link. http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=kp61xbr38 let me know if i can help you further.
Jan 10, 2008 | Televison & Video
Kv40xbr800 standby flashes 7 times, sony 40" Hello. I hope some 1 can help. I've a 41" rear project Sony TV ModelKP-41T65. One day it just decides not to turn on. When you turn on thepower you hear the...
7 blinks on a sony indicate that high voltage has exceeded 33K and the set is going into safety shut down. Check your Horizontal and rgulator circuits. Something in those circuits are causing the increased voltage.Hope this helps let me know if I can help you further.
Dec 02, 2007 | Sony KP-41T65 41" Rear Projection...
Tv will not turn on
The blinking red light is telling you that the set did not start up due to an overvoltage somewhere in the set. Most likely the main power supply has a fault like a bad regulator IC or a component associated with it, or there is a fault in the sweep power supply somewhere. if you have no electronic repair experience, play it safe and call out a tech to assist you with this repair. Good Luck.
Mar 19, 2007 | Toshiba 43H71 43" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
