Question about Zenith B27A11Z 27" TV
Picture is squeezed down to middle with a bright green horizontal
Line across screen my zenith tv has a line through the middle and that's it, i can touch the vertical ic and it is ok for a while. is this major or could i fix it?
  • hughes41 May 25, 2009
    thx guys. i will try the resoldering first. you guys really helped me out.
  • 700 Answers
If you can do it, then just reheat or resolder the vertical ic pin for first step. If this work then no need to change the IC. Good soldering technique is needed. Do this when unit is no power and unplugged from wall socket.
Remember nasty voltages inside, it might caught you.
Posted on May 25, 2009
  • Zenith Master
  • 3,866 Answers
Replace the vertical IC you will need to discharge the flyback and replace the IC it can be done if you know what your doing but there are a lot of youtube videos to show you how this is to be done.
Toshiba 36HF12 TV has a horizontal bright line across no picture
Failure of vertical scan output circuit. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Nov 11, 2015 | Toshiba Televison & Video
JVC AV-27730: horizontal bright line across screen in the
it could be an electrolytic capacitor or the vertical output I.C. in the vertical circuitry,if you remove the rear cover tap on the board in different places and see if the picture fills out or atleast jitters like it might fill out,then it could be just a cold solder joint,then remove the main board and resolder all joints and this should repair the condition you have
Nov 18, 2009 | JVC AV-27730 27" TV
Philips Magnavox 20MS3442/17 Green Line
If this is a tube type or crt type. Your vertical circuit has a problem. Could be the vertical IC loose connection on its board. Or the vertical ic itself is faulty. If just resoldering or refluxing of its pins doesn't help check some minor cmponent within vertical circuit. Or the vertical ic is defective already.
If your not inclined on electronics never do the repair itself, nasty voltages might caught you.
May 11, 2009 | Philips Magnavox 27MS343S 27" TV
Single green line spanning across the screen horizontally
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
Apr 08, 2009 | Mitsubishi CS-27205 TV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
No Picture
This is a problem with the vertical circuit. If you can solder, you should be able to fix this. With teh unit unplugged, open up the back and locate the vetical IC. This should be a small flat IC attached to a heatsink with about 9-11 pins. It may be marked LA7837 or something similar. Try resoldering hte pins. If that fails to resolve the problem, replace the IC. I will look up your specific model and try to get more details.
Dan
Sep 16, 2008 | Zenith Z25X22S 25" TV
White Horizontal line across screen
It is most likely the vertical deflection IC has overheated and lost its soldering. If you open your TV up, it is a 10-15 pin in a row IC sticking out of the motherboard attached to a heatsink. It should be labeled "IC451." Give it a wiggle, see if it affects the picture, You may have to resolder them in place.
The IC may be hard to find, look for a peice of metal that is sticking out of the motherboard, attached to a small chip. I fixed a samsung tv that had it in the middle area.
Mar 27, 2008 | Zenith Z32H41D TV
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Zenith B27A11Z 27" TV Logo
173 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
