Question about Xerox Phaser 8500/DN Printer
Zerox 7750 i have refilled the yellow toner cartridge but the low color indicator is still on
  • 208 Answers
Most likely the toner hopper, is bad. The auger broke or something along that ling
Posted on Dec 04, 2007
Disable status monitor
I suggest if someone is not specialized in refilling ink in an empty cartridge, to get an specialist to the job that they do best to save you time/effort/money.
The cartridge has sensitive pins that the printer detects to determine the amount of ink inside the cartridge; other than this the ink may not have been flowing to the printing mechanism correctly indicating a low level. Try running printer maintenance procedure and replace the cartridge. If the printer indicates a low level, you may need to get a new printer cartridge.
Good luck.
Mar 28, 2014 | Canon PIXMA MP495 InkJet Printer
I have xerox phaser 7750 by mistake i bought 7760 yellow toner shall install it to 7750
Not yet, check with the supplier and ask if it is compatible with the 7750, if not then exchange the 7760 for a 7750 yellow toner cartridge. Once you open the cartridge the supplier will not exchange.
Apr 22, 2013 | Xerox Phaser 7750DN Laser Printer
Hello sir my brother tn-3250 laser toner blinking yellow light
Toner Blinking yellow LED indicates that the toner cartridge is nearly empty. Buy a new toner cartridge or refill the cartridge. Refilling the TN cartridges is quite simple and you can do it yourself.
It is a very simple process. Please refer to this video.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
Jan 17, 2011 | Brother HL-5250dnt Laser Printer
New yellow toner cartridge but no print due to "low yellow toner"
if you got the seals of of the new cartridge, then sometimes opening and closing the toner door will help the indicator go away. I have 2 of these and sometimes it takes a bit for the toner to work it's way into the system.
Feb 20, 2010 | Ricoh Aficio CL2000N Laser Printer
The color images have vertical banding or streaking but the text appears fine. the occasional blace and white image doesn't seem to have this. what can we do to fix the problem? thanks!
Good lunk attempting to follow solution #1, intended for an ink jet printer. LOL!
It seems like you are low on toner for one of the cartridges.
First, try taking out a color toner cartridge, hold it horizontally, and shake end-to-end. This loosens any possible clumps of toner and reactivates static charge between the particles. Repeat this for each color.
Second, print a color page with each toner color separate. For example, a line of cyan text, a line of yellow text, and a line of magenta text. This will help isolate which cartridge has the problem.
Third, check the toner level of each problem cartridge. There is a little clear window on the cartridge you can use for this purpose. Hold the cartridge vertically and tilt slowly toward the side with the window. If you pass a 45 degree angle before the toner appears in the window, it is nearing empty and must be replaced or refilled (yes, refilling is an option). Otherwise, there is likely a different problem, for which I only recommend replacing the cartridge.
Don't forget to empty the waste toner bottle (responsibly, of course). By the time you run low on toner in one of your cartridges, it will likely be nearing capacity.
Aug 16, 2009 | Konica Minolta magicolor 2430 DL Laser...
Konika Minolta 2430 DL won't let me print
Look through the menus on the printer for a setting for "Low Toner" -- the choices of what to do are usually either "continue" or "stop" or something similar (my 2430DL has this option setting) -- set this option to "Continue".
My 15 year old HPs also have a similar setting. However, this will keep it printing when the black runs out, so you will need to check your print production run visually as you go along to make sure the quality is what you need
Jun 22, 2009 | Konica Minolta Magicolor 2530 DL Laser...
We re-filled the toner cartridge and re-installed it, but the red light indicating toner low keeps blinking, also the computor is telling us toner is low
Just refilling the cartridge may not resolve the low toner message. Many cartridges have a sensor chip that must be reset to clear the message. Due to this, many people opt to buy replacements or refurbished cartridges that have had the sensor chip reset.
Aug 15, 2008 | Computers & Internet
Phaser 7750 Toner Levels
did you shake the toner really well first? sometimes this fixes on this machine.
Dec 13, 2007 | Office Equipment & Supplies
7750 toner refill
Most likely the cartridge has its own chip that is not resetable.
Oct 20, 2007 | Xerox Phaser 7750B Laser Printer
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Oct 20, 2007 | Epson Aculaser C1100 Printer
Xerox Phaser  8500/DN Printer Logo
101 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
