Question about SIS741GX-MN Motherboard
Blue screen on start-up. Mobo SIS-741 Chipset SIS741GX Rev 03
One memory slot with 1GB. Installing second slot gets blue screen (do not start windows, stops before).
Bios Agent results find suggests some updates.
BIOS Type: Phoenix-Award BIOS Date: August 31st 2004 BIOS ID: 08/31/2004-SiS-741-6A7I8E19C-00-None BIOS OEM: 741GX-M Ver 1.0F 08/31/2004 - 6.00 PG Chipset: SiS 741 rev 3 SuperIO: ITE 8705/SiS 950 rev 3 at port 002E Manufacturer: Unknown Motherboard: SiS-741
How can I get an updated BIOS for free?
    Scholar:
  • 69 Answers
This problem can be caused by several things. First, are the memory chips exactly identical (brand, type, size, etc.)? If not, that will definitely cause the problem. Second, how many memory slots are there? If you have four, check the manual and make sure you're putting the memory in the correct slots. Some Mobo's require that you put chips in slots A1 and B1 and not A1 and A2. Also, some Mobo's have DDR slots and DDR2 slots, so make sure you're putting the right kind of memory into the proper slots. Some people fudge the memory by putting 400 mhz memory into slower slots, and that works one chip at a time - but if you install a second, identical chip, the system will fail. If all else fails and you've met these conditions, check the type of memory to be sure of the proper fit (use manufacturer's recommended brands and numbers) or try a different chip in the second slot. One chip could be bad.
Posted on May 25, 2009
I hve a sis-741 board i wnt 2knw if i cn instal a 2.6ghz intel cpu on it?
No, it is an AMD socket 462 (socket A) motherboard, which is not compatible with an intel chip.
Feb 07, 2011 | SIS741GX-MN Motherboard
I used 1gb ddr400 to my Asus P4P800-X, it works, but after a few days it always turn black my screen, sometimes i can used it more than an hour & sometimes 5 - 10mins long.. i used another 1gb ddr400.....
The black and blue slots are to indicate where paired sets of identical DIMMs should be inserted. So one pair would use the blue slots and the other pair would use the black. It's possible that your motherboard doesn't fully support this RAM type but you would only be able to find that information at the Motherboard maker's website. Hopefully they still have BIOS updates for that motherboard posted online so you can update it. Sometimes all you need is an update to the BIOS to support newer processors or memory.
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
Jun 30, 2017 | ASUS P4P800-X Pentium Motherboard
Hi... Can you help me in the software of my pc the Video Controller (VGA Compatible) It was gone when I was reformat the PC. Motherboard Manufacturer: Company Name Micro-Star International Motherboard...
Field Value North Bridge Properties North Bridge SiS 661FX Revision 11 Memory Timings CAS Latency (CL) 2.5T RAS To CAS Delay (tRCD) 3T RAS Precharge (tRP) 3T RAS Active Time (tRAS) 5T Memory Slots DRAM Slot #1 256 MB (DDR SDRAM) DRAM Slot #2 512 MB (DDR SDRAM) Integrated Graphics Controller Graphics Controller Type SiS 330 Mirage Graphics Controller Status Enabled Graphics Frame Buffer Size 32 MB AGP Controller AGP Version 3.05 AGP Status Enabled AGP Device SiS 330 Mirage Integrated AGP Aperture Size 64 MB Supported AGP Speeds 1x, 2x, 4x, 8x Current AGP Speed 8x Fast-Write Not Supported Side Band Addressing Supported, Enabled Chipset Manufacturer Company Name Silicon Integrated Systems Corporation
Jul 16, 2010 | Microsoft Windows XP Professional SP2
Memory ram
According to SiS® official document, SiS® 748 chipset has limitation DDR supports:
CPU at FSB 200MHz mode, it will NOT support DDR400
CPU at FSB 333MHz mode, it will NOT support DDR200
CPU at FSB 400MHz mode, it will NOT support DDR200/DDR266
Depends on chipset http://www.asrock.com/mb/overview.asp?Model=K7S8XE
Jul 22, 2009 | Computers & Internet
Asrock p4s61, tried 1gb pc3200 to max memory to 3gb, won't boot.
you quote one of your memory sticks as being pc 2700 when earlier in your text you qoute pc3200.
Firstly pc 3200 is 400 mhz clock speed memory.Secondly, pc 2700 is 333mhz clock speed and you acnnot mix the two on the same board. Thirdly does your board support 3ghz anyway. If you are running a board at 400mhz, pc2700 memory will not run at 400mhz.
Solution, take out the pc 2700 memory and all will be well.
May 02, 2009 | Asrock P4S61 Motherboard
Asus A7N8X-X (third memory slot)
Sounds like either a bad stick of memory or a bad dimm slot . Have you tried the memory on another motherboard ?
Jul 18, 2008 | ASUS A7V8X Motherboard
Memory Update
Hello there.
From your description is sounds like the new Memory is either faulty, or not compatible with your sytem, this explains the error messages and blue screens.
What i would suggest is to download a free program called 'memtest' that you can burn to cd and let your computer load it up before it loads Windows, this will check the memory for any errors and verify that indeed the memory is faulty.
You can find memtest here
Please try this and let us know what happens. If you only purchased the memory then you can get it replaced for free.
Hope this helps.
Jun 28, 2008 | Asrock M266A Motherboard
Help!
  • CPU: Intel CeleronD 2.66GHz CPU
  • Motherboard: ECS 661FX-M
  • Chipset: SiS 661FX
  • Devices
    • 40 GB HDD
    • Combo DVD-ROM/CDRW Drive
    • Floppy drive
  • Memory: 128MB DDR333
  • Operation System: Windows XP Home Edition SP2
  • Accessories Box
    • Keyboard
    • Mouse w/scroll wheel
    • Stereo Speakers
  • Features
    • Integrated SiS Real256E Graphics. SMA up to 64M.
    • Open AGP 8x slot, 3 x PCI slots (1 used)
    • 6 x USB ports (4 back, 2 front)
    • Build in AC97 audio codec.
    • 10/100 build in onboard LAN port and 56K Modem
  • Dec 07, 2007 | EliteGroup ECS u-Buddie UB-Em22+ PC...
    PNY geforce 6600 ddr 256mb agp/ with Asrock k7s41 motherboard When i install PNY geforce 6600, sis 741 chip on mobo seem to be still running. have changed to AGP from PCI in bios, card will...
    PSU 250W usually isn`t good with GF6600 (like and high) videocards. Strongly recommended 350W and high for this configuration (and "350W" - not only numbers in model - for really QUALITY PSUs).
    Sep 25, 2007 | Asrock K7S41 Motherboard
    SIS741GX-MN Motherboard Logo
    621 people viewed this question
    Top Sis Computers & Internet Experts
    ashu k...........
    Level 1 Expert
    David
    David
    Alun Cox
    Are you a Sis Computer and Internet Expert? Answer questions, earn points and help others
