LG 42PX5D 42 in. Plasma HDTV Logo
Steven Bayne Posted on Jan 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pic will not show whole pic in format
When the format key is used. No setting will allow the full pic on the screen.
Lawrence Oravetz
Level 3:
  • LG Master 10,558 Answers
  • Posted on Jan 09, 2014
Lawrence Oravetz
LG Master
Level 3:
Answers
10558
Questions
Helped
2697291
Points
29284
Perhaps the program you're watching is not HD. It won't fill the entire screen no matter how you format the screen.
Nokian73keypadlightproblem
It would b a software problem, hard rest ur cell phone using this procedure: First full charge ur battery, backup all ur data like pics, contacts, and videos etc. Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting. I hope this helps. Regards. :) :)
When i try to formate my nokia n73 phone memory by *#7370# it asks for lock code which should be 12345 but when i try this code it says incorrect code my phone is africa made nokia n73 (vodacom) help me...
Your may have forget ur security code. Now u hav to do is hard rest ur cell phone using this procedure: First full charge ur battery, backup all ur data like pics, contacts, and videos etc. Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting. I hope this helps. Regards. :) :)
19helpful
3answers
How to reset nokia c6 password
the code is 12345 or 00000
OR:
for soft format dial *#7780# or *#7370# which restores the factory settinngs
but if you format the whole phone memory then follow the procedure below ( remember one things this will deletes all your mesages, all contacts, photos, notes etc in the phone memory.. your phone is like a new phone
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.OR:
to format your h.set follow the foll:
Menu>>Tools>>Settings>>phone settings>>general>>Original phone settings
thanks
Nokia n73 software movement how
OR:
thanks
1helpful
I want to format my nokia 1112
go-to the phone menu and select (setting)then go to the option of (Re-store factory setting) the phone will ask for Password type 12345 then press ok .your phone will be reset .
OR:
OR:
thank you
Thanks
1helpful
My sanyo hdtv plasma won't show the whole picture but it worked fine yesterday
Hi my name is Roety,
I can help you with your issue ,
There are a few buttons to adjust the picture size on different make TVs and even on the Cable/Satellite remotes .
1.Format
2.Aspect
3.Size
4.Zoom
5.Wide
6.#
First look on the TV remote, set it to Full ,Fill or Just or 16 x 9 (whichever your model uses) Samsung uses the P size button ,
Then on the cable/dish Box remote stretch (not zoom) is usually best.
On the box remote set the output resolution to 1080i only
And use 16x9 when if offers a choice.
Cable remotes use the # key as a zoom/size button.
Due to the fact there are 16 size/Formats available (3 or 4 being transmitted now). you may have to hit the zoom/stretch button on some HD channels.
But with these settings the picture will mostly stay full and help you avoid image burn from the edges being not on the edge.
Stretch will fill the screen and allow you to read the bottom.
Make sure you are on the correct input, sometimes TVs are connected on multiple inputs
(not necessary, only the HD input is needed)
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
4helpful
My nokia 7710 not start when start display nokia and screen blink and again resatard and display nokia and blink pl solve my problem
try to format use this way
http://i34.tinypic.com/syrods.jpg
1. Press and hold these 3 keys; (check in pic) on keypad and then press the power on/off to switch on the phone.
1helpful
N3110 gprs problem
That means there are many settings are already saved in your Nokia device . Just discard them and try again.
If you couldn't discard them here is another solution :
Just restore factory settings and I'm sure that you'll solve the problem .To restore factory settings here is the way: Switch-off your phone.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
good luck . rate if useful please !
2helpful
My n73 always shows that my memory is full
you need to format your phone. try the soft format of *#7370# , if this doesnt work then do a hard format by folowing these steps
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your phone.
4. Press and hold these 3 keys; Green dial key, * (star key) and no. 3 key and then press the power on/off to switch on the phone.
Do not let go all of the keys, hold until you see a formatting word screen show!
5. After a few minutes when the full phone formatting completed, your phone will be back to original system and factory setttings.
All applications installed will be lost unless you've made a backup on your mmc. You can restore the backup to the C drive again.
You should also try to save all your data on the mmc, that includes pics, mp3, videos ,games. avoid saving data on phone memory unless you have no memory card (mmc)
Formating phone will delete all your files in the phone memory so you should back up all your data before doig a full format
2answers
N93 problem
Make sure to always switch off your phone by pressing the On/Off switch.
Before receiving or sending files via bluetooth, press the menu button for 2 seconds, this will show you how many applications are in use, press C to switch them off, (except bluetooth).
Check that your phone memory isn't over full with pics, videos etc...
You could try a reset input:
*#7780# Restores factory settings.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
