Question about Dell Dimension 4600 PC Desktop
Pc sht down stating thermal error. suppose processr fan not working. can this be the cause of the eror?
Thermal error, pc shut down and error stated thermal error. Fan not working on processor because I hear no sound from fan.
  • 1 more comment
  • pgj0 May 25, 2009
    The fan on processor is not working. power supply fan is working fine. The error states that a thermal error has occurred machine is shutting down!
  • pgj0 May 25, 2009
    Thanks, Computer will not be used untiL fan has been purchased! Know a good place to get one?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Open up the computer and make sure the fan to the CPU is plugged in, if its not then plug it in. If it is plugged in and not working then make sure that nothing is blocking the way of the fan and make sure there is no dust in the fan.
    Scholar:
  • 69 Answers
Most of the time you'll never hear the CPU fan. If you don't hear the normal fan sounds coming from your computer, it is most likely the power supply cooling fan. Hold you hand at the back of the computer where the power chord plugs in, while the computer is running, and test if you feel air blowing on your hand. If you don't, then replace your power supply. Make sure, when checking for a new PS that you get the correct pin count. Best to order from Dell since proprietary systems usually use proprietary parts and a generic PS won't fit in the opening at the back of the computer (alignment of the plug and the fan with the opening, etc.)
Posted on May 25, 2009
  • Lewis Fulkerson
    Lewis Fulkerson May 25, 2009
    Then you need to find out what type of CPU you have, and the type of socket it connects to and purchase a new CPU fan. If you don't do this right away, you'll destroy the CPU!
Thermal event issue
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 19, 2013 | Dell Dimension 4600 PC Desktop
Thermal fuse may be too sensitive
The unit has more than one fan, but dust and such inside on a fan can cause this also, it does not take a lot on the fan blades to slow a fan down enough to trigger this kind of error.
Dec 14, 2012 | Panasonic PT-50LC14 50" Rear Projection...
Thermal event won't ever allow computer to boot at all
"Computer unplugged from power, press the Power On button in, and hold it in. Hold it in for a count of 10 seconds. let go. Do this procedure two more times. (If the Power On LED lights up, do it again) What you are doing is clearing CMOS Error Codes. Check the Processor fan, check the Thermal Paste. Cheap as Thermal Paste is, and what it does for a job, best advice is to simply replace it. Need guidance post back in a Comment. Before beginning make sure the computer is unplugged from power, and you are FOLLOWING Anti-Static Precautions. Regards, joecoolvette"
Brian Packard;
"I cleared CMOS a few times (has jumper on board too) and even put new thermal grese on it....what finally did it was taking out the CMOS battery. As long as it's outl it works just fine, putting it back in causes an error again. Thank you all for your time however and I hope this post can help somebody else too."
Aug 20, 2012 | Gateway 507GR PC Desktop
Emachines t5212 overheat message then shuts down
Three causes of ovheating:
1) Dust. Dust inside the computer, Dust around the vents, fans, cpu and heat sink. Take a can of compressed air and clean the dust out of the computer.
2) A Fan not working. Make sure the fan inside the Power Supply where you plug the power cord in works. Also there is a fan that sits on top of the CPU and Heat Sink. Make sure it works. Normally the system will give you an error message if the fan is not working.
3) Thermal Paste - The Thermal Paste around the cpu and heat sink has dried up or is too thin to keep the unit cool. Apply a fresh coat of Thermal Paste on the CPU and Heat Sink.
May 09, 2012 | E-Machines W Computers & Internet
My hp430 very often shut down itself says 'thermal shutdown' what is the solution?
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 16, 2012 | Computers & Internet
After about 4-5 minutes of operation, the computer shuts off unexpectedly.Everything else appears to work OK, internet access, etc. It doesn't appear to be overheating, but can't be sure.
A computer that shuts off unexpectedly is most of the time caused by heat. Check if the fan in the power supply is working fine by checking the back of the computer. You can take out the CPU too, clean it properly before adding a new layer of thermal paste. In this way, the heating issue will be eliminated.
Aug 01, 2010 | HP Computers & Internet
Working on a dell dimension 5150. it posts then states hardrive error, then states an alert about some thermal error(only stated this on post the first time i turned ti on) then shortly after it turns off....
Yes, it probably is the processor over heating, the bios then shuts the system down to save the processor from damage.
The only way to cure this is by taking the heat sink and fan off the processor, wiping all the old coolent solution of the processor and fan then reapply new coolent, this should solve the shuting down issue.
Feb 03, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Shutsdown without notice could it be the fan mor fans not working
This is typical of a overheating (thermal shut down) CPU problem.
When the CPU overheats and shuts down, it won't bootup again until the CPU cools down. If this is not fixed then the CPU will fail.
This problem is caused by either a faulty fan or the fan and heat assembly is clogged with dust.
Check the fan to see if it spins freely, replace if faulty and clean the dust off the fan and heatsink assembly.
Also apply fresh thermal paste to the heatsink/CPU.
Sep 27, 2009 | Acer Computers & Internet
Have a Mitsubishi WD-62725 that stated on the bottom of the screen the unit would be shutting down because it was getting hot. Check the filter. The unit shut down and after I checked the filter on the...
Have you tried to access the self diagnosis feature to see if it will blink a two didgit error code/ Usually when a set says its going to shut down its due to the thermal fuse or the fans.
Jun 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Acer travelmate 2420
It could also be the CPU "heat sensor" causing a "thermal" shutdown.
Try a hairdryer on cold blow, and point it in where the CPU cooler is!
see does the laptop stay on longer. Thermal paste dosen't usualy "go" unless the heat sink has be detached from the CPU.
I think as you say either the fan or I think the heat sensor.
Aug 22, 2008 | Acer TravelMate 2300 Notebook
Dell Dimension 4600 PC Desktop Logo
248 people viewed this question
Alun Cox
