Question about GE Profile JTP18 Electric Single Oven
Less than 5 youer old ge profile warmed up and died
Our ge profile oven warmed up but died
  • 46 Answers
It has a cicuit board that controls all functions! needs to be replaced1....I would recomend a new one(oven) by the time you pay for the circuit board and the hassle of taking the old one apart! but repair is possible! parts easily availible on the internet
Posted on May 25, 2009
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Replace or fix a 10 year old JTP56 GE Profile double oven
    The heating element is easy to replace and you can buy it online...
    Check out this tip that I wrote about this problem...
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Apr 20, 2010 | GE Profile JTP56 Electric Double Oven
    Oven will not ignite, it is approx. 8 yrs old. 2 years ago the ignitor was changed for a similar problem. Everything works on stove even the broiler. Very dissapointed in the GE profile since I have had...
    Jim your ignitor has gone bad once again.
    You can turn off the gas supply,remove the oven racks,remove the oven base pan,remove the flame spreader to access the ignitor.
    Place a clamp on amp meter over one wire of the ignitor and turn the control on for bake. If the ignitor does not glow at all. It is bad. If it glows and reads 3 amps or less on the amp meter it is still bad.
    A proper functioning ignitor will light and re-light the burner in 45 seconds or less.
    Jan 01, 2010 | GE Ovens
    My GE Profile is about 10 years old. Everything
    cheapest attempt would be replacing temp. sensor....other component if still not functioning,would be the main computer board,which can be very pricey
    Nov 27, 2009 | GE Ovens
    My GE oven heating element heats red hot no matter what temp I put the oven on
    Something is probobly wrong with the thermostat, it gets hot to warm up, but should lessen as it reaches your desired temp. If the thermostat is bad it will just keep going.
    Nov 20, 2009 | GE Profile JTP18 Electric Single Oven
    GE Profile -Installed wall oven - won't heat
    brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
    Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
    Oven taking a long timt to heat to temperature
    Try shutting off the breaker for about 10 minutes - then bring the power back on
    Sep 20, 2007 | GE Profile JT912 Electric Single Oven
    Ge oven problem
    Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
    Jun 07, 2007 | GE Profile JTP56 Electric Double Oven
    Can't make my oven work after a power loss - GE Profile Advantium
    check voltage to oven. if thats ok your control board may be shot.
    Feb 01, 2007 | GE Profile Advantium SCB2001KSS Stainless...
    GE Profile JTP18 Electric Single Oven Logo
    126 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
