My 32" Toshiba LCD HDTV keeps freezing on the same channel and when I try to change the channel or input selection, it doesn't respond(to the remote or directly on the TV.) The only thing that works is turning it off, and it only does that after a delay, and when it powers off it makes a popping sound that is God awful to hear. The TV is only 6 months old, and has never done this before. It just started doing it about 2 hours ago.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 105 Answers
These problems are normally caused by the TV station.
1. Call the TV station responsible and ask for the network engineer.
2. Tell him the Day, Time, Channel, Program, basically every little detail about the problem.
3. The station will normally check it and fix it.
Also, contact Toshiba and tell them. Really this is part of the DTV Transition thing. Many stations are reconfiguring and settin up equipment. They sometimes make mistakes. Don't worry much about it unless it continues for more than a week. If you like the station, I would call right away.
Posted on May 27, 2009
I have no remote for an rca l32wd22 hdtv lcd tv and cannot find the inputs to change to HDMI?
Unfortunately, the L32WD22 doesn't have an Input button on the front panel of the TV. You need a remote control that matches the Input code for the remote. Here's one link to a remote that should work: http://remotes.com/store/rca/l32wd22.html . Other universal remotes may work if you find the correct code if the remote has an Input or Source button.
I hope this helps.
Apr 16, 2013 | RCA L32WD22 32 in. LCD HDTV
How can i change the inputs on the tv?
If you have the remote, there should be an input or source button it? Also, check the buttons on the TV for an input/source button. If there isn't one on the TV buttons, try cycling through the channels, some TV's have the inputs change with the channel buttons too, once cycled down through the channels, it will go through the inputs before starting over.
Regards,
Brandon
Dec 09, 2010 | RCA L32HD31 32 in. LCD HDTV
TV doesn't respond to the remote control.
surface mount capacitors on ir receiver board are shorting
Mar 09, 2010 | Sony KDL32L5000 32 in. LCD HDTV
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
Trouble tuning in empty dtv channels
Just go to the main settings. You will see an "autoprogram" option. Select this and it will scan all available channels and delete non-airing channels
Jun 22, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
No signal
You have changed the input to a selection that does not have a signal. Look at where the cable goes into the TV, this should show the name of that input, then change input back to that exact one via your remote.
Apr 19, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
TOSHIBA TELE/CANNOT TUNE CHANNELS TO CENNECT WITH DVD
it wont be on a chanel, you will need to find the input button on your remote, and change the input that coinsides to the plugs your pluged into on your tv, just change your input untill you see a picture, then remember what one it is
Jan 11, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
TV freezes when switching to a digital channel
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
Dec 05, 2008 | LG 32LG40 32 in. LCD HDTV
Tv does not respond to channel changes
The simpliest solution is always the best - I called the cable service provider; they reported an outage and quickly remedied the situation - but also tried to sell me their digital TV package. Thanks for your response.
Feb 16, 2008 | iLO 3200 32 in. LCD Television
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
Electro Med Services...
