Question about Cameras
Dropped camera. Message reads "Please reinsert video cassette) then message indicates C31:30
  • 2 more comments
  • maata3 May 25, 2009
    The "slaps" did not work. The model number is Sony Handycam HDR-HC3E
    Unfortunately it is not possible to remove the cassette. The mechanism opening the cover lifts the cassette upwards, however it does not open outwards to allow removal and the reinsertion of the cassette.
    I do not know if you received my last reply where I advised the cassette could not be removed and reinserted. When cover is opened the mechanism raises the cassette , however it does not open to allow removal and subsequent reinsertion.
    Before I contacted you I had read the manual, the trouble shooting section and particularly Self - diagnosis/Warning indicators relating to the message C31:30. However, I cannot remove the cassette.
    Brigadier General:
  • 8,619 Answers
Hi
You can follow the "give it a bang" theory and this should work. Procedure is open palm of hand and give it a good knock, after each knock rotate it about 90 degrees. You can knock each side of the camera with open palm a couple of times and it will work. If still it does not work then please tell me the model no .
Please do accept this solution and revert for further assitance.
Thanks
Rylee
Posted on May 25, 2009
  • 1 more comment
  • Rylee Smith
    Rylee Smith May 25, 2009
    Hi
    Thanks for replying. Now please remove and insert the cassette, then operate your camcorder again. Do not perform this procedure if moisture, condensation has occurred. Also you can remove the power source and reconnect it then operate the camcorder again. The best thing would be to press RESET to initialize all the settings.
    Please do accept the solution and revert for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Joe
    Thanks for replying . Please check this manual which will explain everything clearly .
    Sony Handycam HDR-HC3E User Manual
    Thanks
    Rylee
  • Rylee Smith
    Joe
    Trust me the only Prcedure now is open palm of hand and give it a good knock, after each knock rotate it about 90 degrees. You can knock each side of the camera with open palm a couple of times and it should work else you need to go to nearest service center.
    Thanks
    Rylee
I have a sony hvr-hd1000u - I am getting an error message that says reinsert the cassette. Please let me know what you think the issue is. My camera will not work now because of this message. The cassette...
Hello.
This problem is solved by replacing the cassette complet mechanism, part number A1437006A MD (N220) SUB ASSY (S) A
... the cause: the flex is broken.
you can buy it on this website: https://www.servicesplus.sel.sony.com/sony-part-number-A1437006A.aspx
Hollmann.
serviciotecnico@videosistemas.com
Nov 27, 2010 | Sony HVR-HD1000U Camcorder
Reinsert cassette - After inserting a cassette the on screen message reads as follows "reinsert cassette" a further message C:31:23
when ever to get this kind of message just try to fwd the tape mannualy, or just make sure tht when u are rew. the tape dont rewind tht completely....
Jan 04, 2010 | Sony DCR-TRV285E Digital-8 Digital...
Reinsert cassette message
Believe it or not, after having the same problem "re-insert cassette" and "reattach power source", and after talking to Sony and them telling me it would be $111.00 to repair, I hit mine with the palm of my hand twice on each side and twice on the back by the battery and it actually worked--haha Go Figure!!
Dec 10, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
I get an eject symbol and beep and error code c32:11, original issue was that it ate a tape
The error C 32:11 denotes for mechanical unsuitability, This problem appears when the improper insertion of the cassette been done, or lose cassette tape stuck,
In all these situations mechanical adjustment is required, You are suggested to please contact any expert for the mechanical adjustment.
Hope you will understand my sayings.
Thanks for using fixya.
Jul 11, 2009 | Sony Handycam CCD-TRV68 Camcorder
Reinsert the cassette
I had the same problem and had to leave my camera in for service twice, although I am not using it that much. In the end, they told me they had to change the "head" which cost me about 100euros. If it happens again, I think I will throw the camera in the bin!
Nov 05, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
"Reinsert the Cassette"
If the warranty is no longer valid, try to identify what part of the camera is being scraped, then gently bend it back into place. There are a lot of thin metal shields inside the camera that could easily have been dented. I would strongly suggest a repair, as it is a very simple problem that can be easily fixed by moderately skilled hands.
Usually when I got that error message, I would take out the cassette, close it up, take off the battery, and smack it really hard a couple of times. It sounds odd, but it comes from a sony technician. It's the perfect temporary fix.
Jan 25, 2008 | Sony Handycam DCR-TRV260 Digital Camcorder
Re-insert cassette
the flexwire of the camera at the bottom of the mechanical assembly is already cut..it is need to repair that flexwire or replace the mechanical assembly to sony service center...
Dec 31, 2007 | Sony Handycam DCR-HC90 Mini DV Digital...
Casettte insertion
have you contacted canon on the problem if not then I sugest you contact them on their website search for canon in your browser and find the genuine web page with contact info on the only sugestion is clean heads and try again if same message then get it serviced. it could be down to loading mechinisem.
Aug 13, 2007 | Canon ZR200 Mini DV Digital Camcorder
Reinsert cassette error... cannot record via tape
What error message is it giving to you ?? as this will be a good indication of fault.You have tried all the usual things to try by the sounds of things,
May 14, 2007 | Sony Handycam DCR-HC46 Mini DV Digital...
Re-attach the power source followed by Reinsert Cassette
Hai Problem in mechanism. If the tape does not loaded completely, the message will show "Reattach the power source" Please check mechanism. Raghavendra, M/s.prathiksha Electronics
Jan 25, 2007 | Sony Handycam DCR-HC90 Mini DV Digital...
Cameras Logo
47 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
