Question about Refrigerators
Warm rv inside warm refrig.
On the highest setting when the room temp gets to 80+ it won't keep cold.
  • crystaletc May 25, 2009
    I have a Dometic Model RM 2807. When spring(summer )comes the coach inside temp is 80+ the refrig will warm to +45 and the freezer starts to defrost. Cooler temp in the fall and winter it works fine.
    This happens mosty on the gas side and is better on thanksthe ac side.
  • John Tripp
    John Tripp May 11, 2010
    Can you send the model and make of your refrigerator. Some have fans and some small ones transfer heat through the body.
  • Refrigerators Master
  • 4,654 Answers
Domestic Propane Refrigerators have given service technicians very little information on repair of their units. They do have a toll free number you can call to get answers. For Service Center
Assistance Call:
800-544-4881
USA
SERVICE OFFICE
Dometic Corporation
2320 Industrial Parkway
Elkhart, IN 46516
574-294-2511
I am interested in their units and would like to help you. But until they allow others to work with them we just can pass on the information, Thank You, Sea Breeze
Posted on May 25, 2009
I had the same problem but got an electrician who replaced the compressor with a new one and since then I have had not problem. It is a new refridgerator.
How to heating. it's always cooling
Keep heat mode and temp setting+5 degree than your room temp.Still no heat check power to heating element. No power replace heating temp senor. If it's with RV, check power to RV and also warm in suction pipe(higher size pipeline near compressor).
Jan 27, 2011 | LG LS-K2430HL Heat Cool Mini Split Air...
The Heater is not working! It has been on for about an hour and is still blowing cold air!
To get proper heat, keep your temp setting at +5 degree than your temp and also mode in "heat "position. If still noheat, check your heating sensor for closed circuit by an OHMs metre.It it'swith RV, check power to RV.Ifit's with heating element check power to element. If power is there but stillno heat means element defective. Replace new heating element. Thanks.
Jan 24, 2011 | GE Built-In Room Air Heat Cool Air...
Unit comes on and shut off correctly but dosen't heat and cool home equally. Blows cold air in winter and doesn't cool home properly in summer.
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks. To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 09, 2011 | Intertherm Heating & Cooling
My rv air condition also has heat, the heat in it is not getting very warm. So days it will burn u out of it and some days it just blows cool air! Any suggestions. It is a dometic
Check the following if you're unit is not giving heat.
1. Keep temp setting +8 degree from your room temp 2. Keep mode in "Heat". And check the click sound in RV when you turn to heat mode. If one failed out of three your unit will not supply heat.
Dec 15, 2010 | Heating & Cooling
Norcold fridge does not stay cold.we turn it to lp gas or electric and it goes to an n.
Quit playing with it ... absorption refrigs work slow ... and do not recover well ... If yours has a thermostat ... set it a little lower ... check it in the morning ... use a thermometer inside. Keep track of the temps.
Putting warm food in the frig will result in a big slowdown in recovery.
Thanks frr using FixYa.com
Oct 05, 2010 | Thetford RV Refrigerator - N300 Model -...
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Norcold N1095 model stopped working during very cold weather spell. No defaults codes at all showing--just will not cool down. AC and LP both work fine. Refrig just stopped cooling. Contacted norcold...
I have the same problem with my extra fridge in the garage. It has to do with the oil used as a refrigerant in newer models. The cold temprature thickens the oil and it stops cooling. Nothing you can do about it other than opening the door to the fridge to warm the insides up. It works for me. And thank god it's only when it gets very cold outside that this happens. Ps...my garage is insulated and drywalled and it still occors during cold spells.
Dec 17, 2009 | Refrigerators
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
