Laptop not working no lights nothing
Power charger flashing green all the time sounds like clicking noise from laptop not hd nothing like that Sorry to jump in on this but we have the same/similar problem. In our case it is a MD 96420 laptop and it happens when ever we connect the live power cord. The power cord makes no sound and the light is a continuous green until plugged into the computer - then it starts "clicking".
Needless to say the battery is now flat and we need to fix this problem in order to continue to use the computer so for us it's a BIG problem. Took it to a repair shop and they don't want to touch it.
    Sergeant:
    Champion:
  • 212 Answers
Get a new power supply. Try E-Bay
Posted on May 25, 2009
Ds light green,dim green, amber then off when power is turned on
Sounds like you need to send it in for repair. I had sent my console to VideoGame911.com and they repaired mine at a great cost and got it back at the end of the week. Give them a try, they are cheaper than a manufacturer. Good luck!
May 04, 2013 | Nintendo DS Lite
PANASONIC VIERA TH-42PZ82BA 42" PLASMA TELEVISION 1080P Full HD
Your TV is showing symptoms of power supply failure. It needs to be repaired or replaced. The remote has nothing to do with the power supply problem
Mar 21, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
The orange charge light comes on but when I press to start computor nothing happens no green light, the orange light flickers a few times.....I have taken out hard drive and batteries afew time but nothing...
Charger faulty or Motherboard problem.
You can check the power supply of the charger by measuring the DC voltage at the DC jack with a multimeter set to DC volts (red probe on the inner of the jack, black probe on the outer of the jack, should measure 18-20 volts.
Also check the security of the jack in the DC port, make sure it is not loose
See if the Ac adaptor has a green led on it, flashing LED indicates power not being "used " by the laptop
Gut instinct with this being a compaq is that the fault lies in the motherboard
Jan 12, 2011 | Compaq Evo N610C Notebook
Nothing comes on picture blank
Ok
A few things to try
1.) Check the laptop on an external monitor, do you get a picture
2.) Is there power to the laptop from the battery and the charger? Try to see if the charger indicator lamp is blinking green rather than steady green
3.) Can you hear hard drive / fan noises and are there any lights on the laptop?
If the charger is blinking, indicates that power is not making the circuit, check tightness of charging port, if tight, assume fault on motherboard / blown main fuse
If picture on external monitor and not on laptop, assume backlight on screen dead or possibly the inverter
If no noises from HDD or Fan and No lights on laptop, then fault with motherboard
If you do get fan noises etc, but get BLINKING lights on laptop, assume possible fault with graphics chip, repost with details of blinking lights / colour and specific model of laptop
Jan 12, 2011 | Samsung Computers & Internet
The green "battery fully charged"
It sounds like the batteries have gone bad and need to be replaced. Has your chair been sitting unused for a while?
The batteries contain a gel that needs to have current run through it on a regular basis (at least 8 hours once a week) or it will oxidize and solidify. If you attach the charger, what will most likely happen is the green light will either stay green or go to green after a very short time. When you turn on the power chair, nothing happens. The charger will indicate the batteries are full, but instead of being full of power, they are full of crud. Your warranty will most likely not cover replacement as this is due to customer neglect, but your insurance may still cover the replacement batteries if you can wait for the process to go through. Otherwise, you will need to replace the batteries on your own,check your Owner's Manual for the correct type which can most likely be found at Batteries Plus or Interstate Battery. Good luck!
Dec 13, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Hi i have put power supply in anbd powered up my power supp;y shows green light but when i press power on butoon on my e1705 nothing happens no lights flash nothing totally dead
Hi
Please can you try the followinf
1) remove wall charger
2) Remove battery
3) Press and hold power button down for apporx 30 seconds
4) Plug in wall charger
5) Power on laptop
6) If successful plug in battery
Regards
Shauqat
Apr 19, 2010 | Dell Inspiron E1705 Notebook
I have an acer 5920 laptop will not turn on. when i plug the charger into the wall socket the charger has a constant green light. when i plug the charger into the computer the green light flashes the...
sounds like the power jack at back of computer has gone bad, check voltage of battery and see if it has good power if not then it is dead and not getting charged through port the jack at rear generally requires MB replacement and is very expensive and cheaper to get new laptop, u can remove HD from old lap top and copy data over. another choice is to get stand alone charger for laptop battery and use battery mode,
if battery tested good them there is slight chance power switch is bad
Jul 07, 2009 | Computers & Internet
Motorola S9 headset won't charge batteries
This might work if you aren't using the ORIGINAL charger. I had this problem when my cat chewed through the original Motorola charger. I figured my Blackberry charger would work fine, but it didn't. I then discovered that my Blackberry charger was 700mAH and the broken charger was only 550mAH. When I found another charger with the proper power it charged. I also found that it worked when plugging it into my computer with a standard mini USB. I hope this helps.
Jun 03, 2009 | Motorola Mobility S9 Headphones
Loud clicking noise and nothing on screen
Maybe your TV is shutting off the power due to a shorted out backlight bulb.
Nov 17, 2008 | RCA L26W11 26 in. HD-Ready LCD Television
Computers & Internet Logo
164 people viewed this question
David Payne
David Payne
