Question about Frigidaire Pro PHS69EJSS Stainless Steel Side by Side Refrigerator
Temperature fluctuating in freezer and refrigerator; ice maker does not make much if any ice
My frigidaire refrigerator and freezer makes a loud buzzing noise and then the temperature rises in both. It is less than 1 year old and we have had problems with the icemaker since we got it.
  • John Tripp
    John Tripp May 11, 2010
    Is this someting that happens only when the ice maker is working?
  • 213 Answers
SOURCE: GE PSW26M Artica Cooling and Ice Maker Problems
on the back of the frig is a small rectangle panel. inside that panel is the motherboard that controls the whole refrigerator. thoughs boards have been nothing but trouble. one of the problems it causes when it goes bad is the problem your having. replace the board to fix it
Posted on Nov 30, 2007
SOURCE: Loud Buzzing noise
What fan?and does it run only after the ice maker cycles?
Posted on Jul 30, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
Read this, it directly applies to your machine.   After you read this, if you have questions, just ask.
Clicking Refrigerator
Thanks, Bill
Posted on Nov 08, 2008
SOURCE: My Frigidaire refrigerator (FRS20WNF)does not make ice anymore.
did you check your copper line in the back
Posted on Jan 14, 2009
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Posted on Feb 05, 2009
Frigidaire FGHN2844LP ice freezing together. Replaced filter. Twenty hours later, ice maker not working, freezer warm, refrigerator temp. steady 40.
Hello Pat Havard,
I was pulling your owners manual to TRY to determine what could be done to block your freezer door or ice chute open during the filter changing process...
Today the ambient air temperature was at least 90 - 100°F
(degrees Fahrenheit)... To maintain 40°F your refrigerator
has to be working...
You need to look at your FREEZER side...
Your food, a pizza box... ice tray...
SOMETHING... in your immediate WORK area
is blocking vents... or proper closure...
Look at the door switch... make sure your light is OFF
My best guess... FILTER FIASCO induced.
http://www.appliancepartspros.com/frigidaire-ice-maker-243297606-ap5809314.html
The icemaker won't run unless you can freeze cubes...
Carnac the Magnificent
Jul 16, 2017 | Frigidaire Refrigerators
Freezer side is making an extremely loud humming sound. Ice maker is working fine. No ice buildup anywhere in the freezer that we can see. Loud humming goes on for a few minutes each hour.
Hey Joanne, I appreciate your inquiry!
Based off my understanding the freezer side of your Frigidaire refrigerator is making a loud humming noise. The humming sound could be coming from your compressor. If the sound is a new development it may be a possible issue with the fan pushing further against the wall. You may need to seek help from a professional technician for proper diagnosis and repair. This will help you from purchasing any unnecessary parts. Hope this information is helpful to you. -Matt
Dec 30, 2015 | Frigidaire FRS23W3A Side by Side...
Why won't by ice maker make ice?
The icemaker will not harvest if the temperature isn't cold enough. this may be why you are not getting ice.
Oct 04, 2014 | Frigidaire FRS6R4E Side by Side...
Freezer wont freeze ice cubes
Hello Friend, this is Z. Thank you for your post!
I interpret that you are having trouble with the freezer of your Frigidaire refrigerator not freezing ice cubes. It appears that your refrigerator is not properly cooling. Make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. Please allow 24 hours for temperature to stabilize. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your freezer status has changed successfully. Thank you!
Aug 26, 2014 | Frigidaire Freezers
Water leaking on freezer shelves no water in ice maker
Good Morning Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS26H5AS, is not making ice and is leaking water onto your freezer shelves. Please make sure that your freezer is cold enough. Your freezer should be set at a temperature of 0 degrees F. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FRS26H5AS Side by Side...
MY ICEMAKER DOESNT WORK BUT THE WATER DISPENSER WORKS
Hello Valarie Nonos - The issue sounds like it might be related to the temperature in the freezer. What is it set to? Make sure that the temperature is approximately around 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. If it is properly set, then consult a professional to accurately pinpoint any potentially more serious issues like a faulty ice maker or ice maker valve.
Feb 12, 2013 | Frigidaire FRS26RLECS Side by Side...
Fluctuating Freezer and Refrigerator Temperature
check the freezer evaporator thermistor on the top left corner clipped to the evaporator,if its not 16k ohm when at 32 degrees in a glass of ice water after 4 minutes it will defrost too many times and cause this issue,you need to unplug the J1 connector on the mother board in the rear behind the cover and check terminals 4 & 5 un the plug,not on the board though
Feb 07, 2013 | Refrigerators
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
I have a new Frigidaire 20.6 cu. ft. top freezer without icemaker. When it turns on or goes in its cycle it makes a knocking sound behind freezer compartment, then stops. is this normal? . P.C Richards...
This is normal. It is the sound of the refrigerant flowing through the coil on start up. This will cause the knocking sound you are hearing. It should only last for about 7-10 seconds. You might also hear a cracking noise due to the insulation expanding and contracting due to fluctuating temperature. Refer back to your owners manual under normal operation sounds. Hope this helps.
Oct 20, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Frigidaire Frig side by side making a loud buzzing noise
it sounds like the compressor, or something near it. it is generally the only moving part in a refrigerator other than the door, so would be my first guess. If it is constantly running, but staying cool in the freezer there may be a small leak somewhere or the compressor is losing power, and pumping slower.
Jun 15, 2009 | Frigidaire FRS26H5AS Side by Side...
Frigidaire Pro PHS69EJSS Stainless Steel Side by Side Refrigerator Logo
279 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
