Question about Adobe Photoshop 6.0 for PC
Editor not working
When trying to open Photoshop elements 6.0 in vista, I get Adobe Photoshop Elements 6.0 (Editor) has stopped workiga problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. I get not solution and the problem continues on.
  • 108 Answers
OK U SHOULD CONTACT THE PRODUCT DEALER BUT ONCE U CHECK THE SYSTEM REQUREMENTS AND CHECK ALL THE COMPONETS ARE THEIR OR NOT IF ANY ONE IS NOT THEIR U SHOULD INSTALL AND IT WILL WORK AND ONE MORE U SHOULD DOWNLOAD THE ADOBE PHOTOSHOP UPDATES U CAN DOWNLOAD FROM HERE ok rate me please 100%
Posted on May 28, 2009
Every time I try to open the program, I'm getting this: Adobe Photoshop Elements 6.0 (Editor) has stopped working. Windows can check online for solution to the problem. Check online for a solution and...
Do Solution 1 first, then try Solution 2. Proceed to Solution 3 only if you wish to operate your device directly from within Photoshop or Photoshop Elements Editor.
Solution 1: Disable the TWAIN plug-in. Photoshop and Photoshop Elements Editor do not load plug-ins whose file name begins with a tilde (~). Rename the TWAIN plug-in to prevent Photoshop and Photoshop Elements Editor from loading it.
To disable the TWAIN plug-in:
  1. Do one of the following:
    • If you are using a 32-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    • If you are using a 64-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files (x86)\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    Note: If you do not know which edition of Windows you are using, see Determine whether your computer is running a 32-bit or a 64-bit edition of Windows (kb407673).
  2. Rename Twain_32.8BA to ~Twain_32.8BA. (You may not see the filename extension .8BA.)
When the TWAIN plug-in is disabled, you cannot operate your device by choosing File > Import > [Device name] in Photoshop or Photoshop Elements.
If you do not wish to operate your device directly from within Photoshop or Photoshop Elements, then you can use other software -- such as the software that came with the device, the Windows Scanner And Camera Wizard, or Windows Photo Gallery -- to operate the device and save image files from the device. (For instructions, see the documentation for the other software.) Then you can open those files in Photoshop or Photoshop Elements.
Solution 2: Disable older scanner files in Windows. If Solution 1 does not solve the problem, open the C:/WINDOWS/Twain_32 folder and move all files in that folder except the wiatwain.ds file to another location. Older scanning files in this folder can cause problems with more recent drivers and applications.
If you would like to operate your device directly from within Photoshop or Photoshop Elements, then proceed to Solution 3.
Solution 3: Troubleshoot installed drivers and re-enable the TWAIN plug-in. If you use a scanner, all-in-one printer, or another TWAIN-compatible device on your system, then the device's driver may be out-of-date. Download the latest version of the driver for your device from the manufacturer's website. Follow the manufacturer's instructions to install the driver. (If you have more than one TWAIN-compatible device, then download and install the latest driver for each device.)
After you have installed the latest driver for each device, re-enable the TWAIN plug-in and restart Photoshop or Photoshop Elements.
To re-enable the TWAIN plug-in:
  2. Rename ~Twain_32.8BA to Twain_32.8BA. (You may not see the file name extension .8BA.)
If Photoshop or Photoshop Elements successfully starts with the TWAIN plug-in enabled, then you can operate your device by choosing File > Import > [Device name].
If Photoshop or Photoshop Elements fails to start, then the driver for one or more TWAIN-compatible devices that you no longer have or no longer use may be causing the problem. (A driver will remain on the computer even after you disconnect a device.) Identify each device that you do not use, and then follow the manufacturer's instructions to completely remove each device's driver.
After you remove the driver for each device that you do not use, restart Photoshop.
If Photoshop or Photoshop Elements still fails to start, then the driver for one or more of the devices that you currently use is incompatible with the TWAIN plug-in. In that case, disable the TWAIN plug-in (see Solution 1: Disable the TWAIN plug-in) and leave it disabled. (You may also wish to periodically check the device manufacturer's website for driver updates. If an updated driver becomes available, then repeat this solution.)
Jul 31, 2010 | Adobe Photoshop 6.0 for PC
How can I get photoshop elements 6 to work on my computer now that I have windows 7
The system requirements for Photoshop Element 6 shows to be compatible with Windows XP and Windows Vista.
You may want to check with Adobe to see what os Photoshop Elements 6 supports., or to see if there is a patch or update.
You might also try out the XP mode in Windows 7 to see if you can get it installed and working.
Mar 28, 2010 | Adobe Photoshop Elements 6: Windows
What does attempt to access invalid address mean in Adobe Photosh
Please turn your antivirus software to gaming mode and problem will be sovled.
Nov 17, 2009 | Adobe Photoshop Elements 4.0 plus Premiere...
Photoshop Elements 7 is not working on my vaio with vista 64 bit
Starting Adobe Photoshop Elements, the Editor returns the error message "Unable to continue because of hardware or system error. Sorry, but this error is unrecoverable," and the Organizer returns the error message "Interface not found."
Solution: Enable the Event log service.
1. Choose Start > Settings > Control Panel.
2. Double-click Administrative Tools, then Services.
3. Right-click Event Log and select Start.
Note: The Event Log can only be disabled in the Microsoft System Configuration utility (msconfig) under the Services tab, but should never be turned off.
Background information
The error messages "hardware or system error..." or "interface not found" when you start either the Editor or Organizer indicate a system level problem. These messages display if Event Log is disabled. The Event Log is a Microsoft service that should never be disabled.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Sep 23, 2009 | Adobe Photoshop 6.0 for PC
Photshop Elements 7 editor won't open
Are you trying to use it with a tablet device? Because some tablet devices override the drivers that are dependent for Photoshop. If this is not the problem, please leave a comment and I'll get back to you =)
Jul 16, 2009 | Adobe Photoshop 6.0 for PC
Adobe Photoshop Elements 7 Editor "stops working"
Even though this says Elements 6, it still works for 7. The only difference is the TWAIN file is at: C:\Program Files (x86)\Adobe\Photoshop Elements 7.0\Locales\en_US\Plug-Ins\Import-Export
http://kb2.adobe.com/cps/408/kb408846.html
Jul 15, 2009 | Adobe Photoshop 6.0 for PC
Adobe photoshop elements (editor) has stopped working
Even though this says Elements 6, it still works for 7. The only difference is the TWAIN file is at: C:Program Files (x86)AdobePhotoshop Elements 7.0Localesen_USPlug-InsImport-Export
Jun 10, 2009 | Adobe Photoshop 6.0 for PC
Adobe Photoshop Elements 6.0 (editor) stopped working...
It's most likely incompatible with your system. That's a very old version of Photoshop.
May 10, 2009 | Adobe Photoshop 6.0 for PC
Photoshop does not work on vista
When Adobe began shipping Photoshop® Elements 5.0 and Adobe Premiere® Elements 3.0 software in September, final versions of Microsoft® Windows® Vista were not available to complete the testing required to ensure compatibility.
Shortly after Windows Vista becomes available to consumers, Adobe plans to release updates for Photoshop Elements 5.0 and Adobe Premiere Elements 3.0 to provide compatibility with Windows Vista.
Updates for existing Photoshop Elements 5.0 and Adobe Premiere Elements 3.0 owners will be available as a free download from adobe.com, and updated Vista-compatible versions of Photoshop Elements 5.0 and Premiere Elements 3.0 will become available in the same timeframe.
tnx 4 using fixya!!!
Nov 02, 2008 | Computers & Internet
Adobe Photoshop 6.0 for PC Logo
198 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
