Question about Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool Gold Range Mod GLP84900
I have this problem with my ceramic top electric range there isn't any heat coming from the bottom of the stove when in bake mode. the top element heats up fine. I believe there is a hidden bottom element as the oven is self cleaning. There are no replaceable fuses on the top flip top panel. There are 2 tiny reset buttons under the florescent bulb , but they appear to be normal. removing the back cover shield doesn't show any fuses either with no access to a bottom element. Any help on this topic would be appreciatedreplaced my bottom hidden element of my whirlpool stove and it doesnt heat up. what can cause this to happen. is the new elament faulty too?
    Sergeant:
  • 296 Answers
Hi
chek this below link for the scematic of your product,guess u will have an idea of the parts inside the machine:-
http://www.whirlpoolparts.ca/parts/fspShow.php?model=GLP84900&folder
AND
Check the burner ports near the ignitor for blockage. It appears that the ignitor was not mounted correctly, and causing the problem.
all the best
regards
Posted on May 25, 2009
Is it okay to use glass whistler tea kettle on ceramic stove top range
I've seen mixed results across the internet on this one. From personal experience, for some reason, my glass teapot left some sort of stain on my ceramic stovetop. It also took longer to heat. I then went out and bought a simple metal one and have been pretty satisfied. If cosmetics are a concern, it's not too difficult a step to pour the water into your teapot after the fact, right?
Jul 23, 2014 | Frigidaire Ffed3025ls 30 Smooth Top...
Bottom elment gone how do you replace it.whirlpool gold model #GLP84900.
I took off the side panel - 3 Screws - from there you can see the burner - 2 screws - pulled it out sideways.
But you should know that 9 out of 10 times when they blow they take out the computer as well. So before you change the burner check to see if you have power to it. Or call a tech to make sure.
I changed the burner, and found out it had blow the computer as well. 350.00 for a new chip. Bought a new stove. LOL
Mar 01, 2010 | Whirlpool GR465LXLS Electric Kitchen Range
Lowes installed new whirlpool gold range yesterday. Turned on a top burner and there was a loud "bang" and the circuit breaker tripped. Now doesn't heat up at all. Range manual lists the same electrical...
Hello. DEFINITELY call Lowes and report what happened. They must come out with a new range and swap it for the defective one while it is still under warranty. Do not wait. Regards, Joe
Dec 15, 2009 | Cars & Trucks
I believe there is a mouse nest in the insulation of my whirlpool ceramic stove top, how do I remove the stove top to clean it out?
Open the oven door and locate the screws under the bottom of the front edge of the cook top. Remove the screws and the cook top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
If there is evidence of any rodent infestation, make sure you do a thorough inspection of all internal wiring. Mice love to chew on wire insulation. Any bare wires can result in appliance failure, electric shock, or become a fire hazard. Make sure you do not use the range until repairs are made if there are signs of any wire damage.
NOTE: Ensure you also check the wiring inside the operator console. Remove the back panel to access.
If you have questions, please let me know. I hope this helps you.
Aug 01, 2009 | Whirlpool Accubake RF362LXTS Electric...
Whirlpool Gold Range Error code EO F2
On this website: http://www.repairclinic.com/0078.asp#Whirlpool , it shows all of the codes for the Whirlpool errors. Based on the remarks, if it shows a "4 digit failure code" it is "Shorted keypad"
"Replace Electronic Range Control/Clock (ERC)"
But verify this as I am not an appliance repair specialist. I am a computer nerd who just knows how to find information. I am actually trying to figure out an answer to my own problem with my Whirlpool Gold Accubake.
Dec 11, 2008 | Whirlpool GR773LXSS - Stainless Steel...
Oven heat
There is a bottom hidden element that is the main element used for baking and cleaning. If its not heating then the element has gone bad and needs replacing. If you have a volt meter then you can confirm this by checking the voltage between the two terminals sticking out of the rear of the range. There should be 240vac across the two. If you have that then you need a new element if you don't then you need a new control board.
Nov 03, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Hi I have a whirlpool gold range mdl GJSP 84902 and had replaced the bottom hidden element after finding out it wasn't getting any heat. So replacement took a little figuring out. it ws easy after a removal of screws and pulling out the whole oven casing out fron the front. Anyhow I still don't get enough heat generate from the bottom element, what other cause are there. checked fuses wiring all is connected HELP ME PLEASE !!!!! thank you Paul
Nov 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool 465 large capacity electric ceramic top oven failure
How much time I need to set to do the oven self cleaning ?
I have electric Whirpool oven 465 automatic
Oct 18, 2008 | Maytag MES5870A Electric Kitchen Range
We have a Whirlpool electric ceramic stove top. All of a sudden we are unable to regulate the heat i.e. it stays hot all the time and therefore cannot simmer anything.
Its hard to suggest anything since you did not give us the model number of your range and which of your unit is defective
regards
Sep 10, 2008 | Whirlpool Kitchen Ranges
Whirlpool GR465LXLS Electric Kitchen Range Logo
157 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
