Question about Acer Aspire One PC Notebook
Startup main error problem
I have an acer aspire1. i istalled a program on it and when the program starts a window pops up that says Startup Main: 339-Component 'Softlocx3.ocx' or one of it's dependencies not currently registered: a file is missing or invalid application will shut down. how can i fix this problem without haveing to download a registry defender or regcure or something like that.
  • jill pittman May 25, 2009
    i did what you said but the message still appears when i try to start the program. the operating system i have is windows xp
    Sergeant:
  • 206 Answers
Hi
Save the data you want and then re-install windows and the drivers again its the only way to restore your pc or laptop
I fix laptops and computers
Cheers
Posted on Nov 26, 2012
  • Acer Master
  • 2,404 Answers
Depending on the operating system your running, click on the start button in the bottom left or the vista icon, then either click on "RUN" or in the search box type MSCONFIG and press enter.
Click on the startup tab and then clickon the disable all button. Then click on apply and then okay and then let the computer restart.
After it restarts if the error message stops appearing then you know its something that is starting up when windows boots.
Go back into msconfig and then you can enable any of the programs that you want to startup instead of the ones that you don't.
Posted on May 25, 2009
Ricoh mpc 6000 sc 670
Engine startup error - sudden communication reset between controller and VBCU 7/29/2008 Helpful SC 670 Engine startup error - VBCU defective 7/29/2008 Helpful SC 670 Engine startup error - VBCU installation incorrect 7/29/2008 Helpful SC 670 Engine startup error - LCT lift tray sensor was shorted 9/2/2008 Helpful SC 670 Engine start up error. Check main power supply, cn 409 for 5volts 7/20/2009 Helpful SC 670 Engine startup error - Replace laser unit and follow SP adjustments after laser unit replacement 4/5/2010 Helpful SC 670 Engine startup error - IOB board defective 6/8/2010 Helpful SC 670 Blown fuse 2 on VBCU due to shorted harness in registration motor harness 6/8/2010 Helpful SC 670 Engine start up error - Check wiring for df feed in cover.. 8/6/2010 Helpful SC 670 Engine startup error - Replace finisher main board 10/26/2010 Helpful SC 671 Controller mis-match error - Install correct controller b
THIS UNIT IS VERY HARD TO WORK ON YOU NEED A SERVICE CALL, GOOD LUCK! -Carl
Mar 31, 2015 | Ricoh Office Equipment & Supplies
Tip
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 | Computers & Internet
Tip
Disabling Unnecessary Programs At Startup:
Many programs add portions of themselves starting automatically on every login.This can be either in the Startup Folder or the Registry. One easy way to tell is by looking at how many icons are in your system tray. If you have a large number, perhaps unnecessary resources are being allocated them as well as increasing your boot time. Typical examples are Microsoft Office, Office FindFast, Real Player, ATI Video setting etc. You can remove them in one of three main ways:
In the Start / Programs / Startup Folder
In the Registry under HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ Run
on Mar 07, 2008 | Microsoft Windows Vista Ultimate Edition
I cant use my camera because its being used but another app... but i have no idea how to locate or close the app
I would suspect it in a startup program, say CyberLink. It's set to start at Windows Startup. Open the webcam software for your laptop and disable Start at Windows, OR download CCLEANER freeware at : http://www.filehippo.com/download_ccleaner/ .This is a good program to learn to use. You can clean the junk from your machine and in the TOOLS section, STARTUP, look for your webcam startup program, disable it. Disable ALL unnessary startup programs to speed boot and shut downs.
Jan 06, 2013 | Acer Aspire 5600U all-in-one desktop
Dell dimension 3100 wont load to main screen
You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 29, 2012 | Computers & Internet
Upon starting my laptop, an error pops up prior to my desktop's icons stating that (Pardon the incorrect formatting) C://documents Cannot be found Then I hit okay and it loads everything fine. Then
Nov 02, 2012 | Computers & Internet
Schedule record application starts automatically in background when system restats
Try this:
Disabling Startup Programs in Windows For some programs, it's smart to have them start with Windows, such as anti-virus and firewall software. However, for most programs, starting them at boot-up just wastes resources and extends startup time. There is a tool installed with Windows, called MSConfig, that allows you to quickly and easily see what's running at startup and disable the programs you prefer to run on our own after startup as needed. This tool is available and can be used to disable startup programs in Windows 7, Vista, and XP.
NOTE: MSConfig can be used to configure several things other than just startup programs, so be careful what you do with it. If you're not sure about using it, just follow the steps in this article and you should be fine.
To run MSConfig, open the Start menu and type "msconfig.exe" (without the quotes) in the Search box. As you type, results display. When you see "msconfig.exe," click on it or press Enter, if it is highlighted.
NOTE: If you are using Windows XP, open the Run dialog box from the Start menu, type "msconfig.exe" in the Open edit box, and click OK.
Click the Startup tab on the System Configuration main window. A list of all the startup programs displays with a check box next to each one. To prevent a program from starting up with Windows, select the check box next to the desired program so there is NO check mark in the box. Click OK once you have made your choices.
A dialog box displays telling you that you may need to restart your computer for the changes to take affect. Click Restart to restart your computer immediately. If are not ready to restart your computer, click Exit without restart.
Aug 26, 2012 | IBM Lenovo ThinkPad L412 Notebook
Hello my Acer aspire one kav10 is stuck on windows xp loading screen. I have already tried to system restore to an earlier point by using safe mode but when the laptop starts up again it gets stuck on the...
One of the drivers or programs that is set to launch during boot is corrupted. You will have to find out which and uninstall / upgrade it.
Boot in Safe Mode, click Start, Click Run and type msconfig and hit enter - the startup management window will launch. Click on the Startup tab and untick all the programs in there. Now reboot. If you get the same error then the problem is with a driver - uninstall them all then download the latest versions from the Acer Support site and install them one by one. If the problem is fixed then one of the programs is corrupted - open msconfig / Startup again and tick one program at a time with reboot until the problem returns: uninstal that program.
Feb 26, 2011 | Computers & Internet
How do you change the startup programs so startup dont take so long?
go to start>run and type msconfig hit enter
Go to startup tab and remove checkmarks from programs you dont want to start automatically with each windows start....
Hope this helps!
Aug 22, 2010 | Acer Aspire One D150-1587 Netbook
Startup error problem 339
The program is either not compatible or corrupt.
May 25, 2009 | Acer Aspire One PC Notebook
Acer Aspire One  PC Notebook Logo
131 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
