Question about Microsoft Xbox 360 Console
Error code: E 73, one red light
Basically, my xbox has had one red light on the bottom right corner for about two months now, and the error code is E 73. My xbox warranty is gone, and I've already had it fixed two times before this, and I don't want to spend $100 knowing that it could easily break for a fourth time. The weird thing is, when I tried turning my console on today, it actually worked! In hopes that the problem miraculously disappeared, I turned it off and on again. It doesn't work. I don't have the money or patience to get it fixed for a third time, and buying a new xbox is completely out of the question. Is there anything I can do that doesn't require me to do a lot of re-wiring (I am not very tech-savy) or pay hundreds of dollars just to fix it? Please help.
  • 6,784 Answers
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
this is a integrated part that is shared with the motherboard and, this will require the hands of a Microsoft tech. the entire port will need to be clipped and replaced on the mother board, via solder iron. this actual port is not available for purchase. use this number below to contact Microsoft.
1-800-4MY-XBOX
Posted on May 25, 2009
    Problem Solver:
  • 5 Answers
Hello!!! This is a serious problem you have here but nothing is imposibble, look, i think the "GURU" who answer you (no offense) really can't help you because he is a worker on this sh%& of microsoft, who aren't be able to do a good console like nintendo but this isn't the case so let's get it. I have the same problem about 2 months ago what i do is void the warranty (which doesn't work for anything) and open my console till i get it with the CPU and the GPU, then i grab my professional heat gun and set it to 500 grades centigrade, and for about 5 min reheating the area who doesn't work (is the area who contains the GPU, the XSB and the ANA) with slow motions and then change his paste (i really recommend you the famous Artic Silver) and if that doesn't work do it all again (i do it about 4 times till i reapir the console) i hope this work for you like it do for me.
P.S. don't do the things that shows in youtube it's a really waste of time!!!
(sorry for my english but i'm from guatemala (latin country))
Mago 6246!!!
Posted on Jun 09, 2009
Red flashing light in bottom right hand corner of xbox 360 arcade console. Says System Error contact customer support error code E 73.
the best thing to do is to contact the customer support because there are many occasions on which it can show you this message and you can't be sure which is which.
hope dis helped you?please rate
Dec 16, 2010 | Microsoft XBOX 360 ARCADE Console
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
you have a problem with you ethernet port,phone microsoft if still covered by warranty
Mar 21, 2010 | Microsoft Xbox 360 Console
Error 73 one red light bottom right hand corner
E73 is easy to fix. What you'll have to do is do the "overheating reflow solder trick" Which is basiclly heating your 360 up to be super hot, so the solder joints can flow back together. http://www.youtube.com/watch?v=67sbmlJ2_ek you can do it this way but... there is a better way if you google it.
Mar 07, 2010 | Microsoft Xbox 360 Console
When i turn the x box on it has one red light flashing in the bottom right hand corner and the error 73 message comes on
The problem has aroused due to the overheating of the console. The HANA scaler chip on the motherboard got overheated and this deals with the display on your console and that is why your Xbox is showing the e74 error.
If your Xbox 360 console is under warranty period, then without coming to the decision of self repairing you should send your console to the Microsoft service center and let them work for you. What is important on your part, you have to be patient for 5 weeks without gaming until you get back your favorite console repaired.
Fixing 1 red light (E74) error is not a problem at all, so long as you have quality resources. Read the repair guide by clicking the link below, and you will know how to fix the Xbox 360's 1 red light error. This quality step by step instructions guide found here will help you crack the 1 red light error with ease, which will ensure you can start enjoying gaming rather easily.
http://fix-my-xbox360.info/
Jul 22, 2009 | Microsoft Xbox 360 Console
Exbox 360
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jan 05, 2009 | Microsoft Xbox 360 Console
XBOX ERROR
The official Microsoft KnowledgeBase article is here http://support.microsoft.com/kb/941377/
You need to call 1-800-4MY-XBOX - your Xbox needs repair or replacement. It's now basically useless.
Nov 22, 2008 | Microsoft Xbox 360 Console
E 73
Good Luck
Nov 04, 2008 | Microsoft Xbox 360 Console
One red light bottom right hand corner
hope it helps...
Jul 22, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
1,675 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
