Question about Fisher and Paykel DG05 Gas Dryer
Squeaking dryer drum when operating
I have a Fisher Paykel DG05 gas dryer. It is making a moderate to loud sqeaking noise when the drum is turning. I can turn it by hand, no squeak. The noise cycles as the drum turns, loudest at one point then again at each turn. Everything else is working. Not sure how to open it up to look inside- top or back. Is the top held with clips, I tried to pry it with a screwdriver but I didn't want to break anything.
  • 46 Answers
Sounds like you need to adjust the motor that turns the drum to tighten the drive belt..... you do this from the back or bottom...
Posted on May 25, 2009
The dryer is squeaking/squealing during operation. It is a high-pitched noise that is rather loud. It is also getting very hot. We vacuumed the lint bucket area behind the cover, which fixed the...
I am having a similar issue. I had a tech out to look at it and he recommended replacing the drum bearing and idler jockey pulley. ($419.95) Ouch. I am going to do this on my own. I ordered the part from paykelfisherparts.net. Part # 479332 Drum Bearing Kit $79.91.
Check here for more info. This was exactly what I found on my machine (DGGX1) http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/731-fisher-paykel-dggx1-top-load-dryer.html
I did not totally trust the repair dude. He was wierd and not very thorough. I can tell the bearing is bad, if there are still noises I will order up the jockey pully thing and see if I can figure that out.
Here is a link to the service manual. (https://docs.google.com/fileview?id=0B5If-wTgYWH5OGNkY2RmZDEtMWU4OS00MjgwLTg3OWEtMmRlZjY0N2I5MzYy&hl=en)
Good luck
Jan 17, 2011 | Fisher and Paykel DGGX1 Electric Dryer
We bought a fisher and Paykel gas dryer DG05 in 2002. The Drum when tumbling started squeaking this morning. Just in time for the new year. lol. I also noticed that after about 2 minutes, the squeak...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 01, 2011 | Fisher and Paykel Dryers
Hello, My Fisher Paykel dryer is making a very loud motor noise when it is on Does this ring a bell??
The motor is going bad...
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 20, 2010 | Fisher and Paykel DG06 Gas Dryer
Its making a scrapeing sound when its tumbling . it seems the front of the drum is rubbing .
Sounds like it needs the slide bearings replaced. They are usually semicircular slides that the drum rides on made of neoprene or some other high impact plastic.
Sep 12, 2010 | Fisher and Paykel DG05 Gas Dryer
Dryer is squeaking when running. how many slides of each color are needed to repair it? and might I find a manual on how to replace them?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 31, 2010 | Fisher and Paykel DG05 Gas Dryer
Dryer is not working makes loud noise
heatman101
Jun 18, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer drum squeaking when operating
heatman101
fggf
May 24, 2009 | Fisher and Paykel DE60FA-US Dryer
ED55 dryer making screeching noises
sounds like the rear tub bearing has worn out that would explain the noise and if it got too bad the bearing can break causing the drum to stick and not be able to turn
Nov 26, 2007 | Fisher and Paykel DG05 Gas Dryer
Fisher and Paykel DG05 Gas Dryer Logo
759 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
