Question about Adobe Photoshop 6.0 for PC
Adobe Photoshop Elements 6.0 (editor) stopped working...
SAME AS LISTED ABOVE
  • 489 Answers
I think your last configiration that Adobe elements 6.0 knows has been changed.  sometimes  some USB flash does this. i think you need to re install your adobe
hope it works. sorry my english.
Posted on May 28, 2009
  • 6,784 Answers
I need more detail in order to give a proper solution. tell me exactly what happen before it stooped..
Posted on May 24, 2009
Every time I try to open the program, I'm getting this: Adobe Photoshop Elements 6.0 (Editor) has stopped working. Windows can check online for solution to the problem. Check online for a solution and...
Do Solution 1 first, then try Solution 2. Proceed to Solution 3 only if you wish to operate your device directly from within Photoshop or Photoshop Elements Editor.
Solution 1: Disable the TWAIN plug-in. Photoshop and Photoshop Elements Editor do not load plug-ins whose file name begins with a tilde (~). Rename the TWAIN plug-in to prevent Photoshop and Photoshop Elements Editor from loading it.
To disable the TWAIN plug-in:
  1. Do one of the following:
    • If you are using a 32-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    • If you are using a 64-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files (x86)\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    Note: If you do not know which edition of Windows you are using, see Determine whether your computer is running a 32-bit or a 64-bit edition of Windows (kb407673).
  2. Rename Twain_32.8BA to ~Twain_32.8BA. (You may not see the filename extension .8BA.)
When the TWAIN plug-in is disabled, you cannot operate your device by choosing File > Import > [Device name] in Photoshop or Photoshop Elements.
If you do not wish to operate your device directly from within Photoshop or Photoshop Elements, then you can use other software -- such as the software that came with the device, the Windows Scanner And Camera Wizard, or Windows Photo Gallery -- to operate the device and save image files from the device. (For instructions, see the documentation for the other software.) Then you can open those files in Photoshop or Photoshop Elements.
Solution 2: Disable older scanner files in Windows. If Solution 1 does not solve the problem, open the C:/WINDOWS/Twain_32 folder and move all files in that folder except the wiatwain.ds file to another location. Older scanning files in this folder can cause problems with more recent drivers and applications.
If you would like to operate your device directly from within Photoshop or Photoshop Elements, then proceed to Solution 3.
Solution 3: Troubleshoot installed drivers and re-enable the TWAIN plug-in. If you use a scanner, all-in-one printer, or another TWAIN-compatible device on your system, then the device's driver may be out-of-date. Download the latest version of the driver for your device from the manufacturer's website. Follow the manufacturer's instructions to install the driver. (If you have more than one TWAIN-compatible device, then download and install the latest driver for each device.)
After you have installed the latest driver for each device, re-enable the TWAIN plug-in and restart Photoshop or Photoshop Elements.
To re-enable the TWAIN plug-in:
  2. Rename ~Twain_32.8BA to Twain_32.8BA. (You may not see the file name extension .8BA.)
If Photoshop or Photoshop Elements successfully starts with the TWAIN plug-in enabled, then you can operate your device by choosing File > Import > [Device name].
If Photoshop or Photoshop Elements fails to start, then the driver for one or more TWAIN-compatible devices that you no longer have or no longer use may be causing the problem. (A driver will remain on the computer even after you disconnect a device.) Identify each device that you do not use, and then follow the manufacturer's instructions to completely remove each device's driver.
After you remove the driver for each device that you do not use, restart Photoshop.
If Photoshop or Photoshop Elements still fails to start, then the driver for one or more of the devices that you currently use is incompatible with the TWAIN plug-in. In that case, disable the TWAIN plug-in (see Solution 1: Disable the TWAIN plug-in) and leave it disabled. (You may also wish to periodically check the device manufacturer's website for driver updates. If an updated driver becomes available, then repeat this solution.)
Jul 31, 2010 | Adobe Photoshop 6.0 for PC
What does attempt to access invalid address mean in Adobe Photosh
Please turn your antivirus software to gaming mode and problem will be sovled.
Nov 17, 2009 | Adobe Photoshop Elements 4.0 plus Premiere...
Photshop elements 6 organizer dont start
i am an employee of adobe, I am aware of this issue, iam sendiing you an adobe engineer designed link to reslve this issue. i would suggest you to follow the given steps in detail:-
Please try this link:-http://go.adobe.com/kb/ts_kb406966_en-us
Sep 19, 2009 | Adobe Photoshop Elements 6: Windows
Photshop Elements 7 editor won't open
Are you trying to use it with a tablet device? Because some tablet devices override the drivers that are dependent for Photoshop. If this is not the problem, please leave a comment and I'll get back to you =)
Jul 16, 2009 | Adobe Photoshop 6.0 for PC
Adobe Photoshop Elements 7 Editor "stops working"
Even though this says Elements 6, it still works for 7. The only difference is the TWAIN file is at: C:\Program Files (x86)\Adobe\Photoshop Elements 7.0\Locales\en_US\Plug-Ins\Import-Export
http://kb2.adobe.com/cps/408/kb408846.html
Jul 15, 2009 | Adobe Photoshop 6.0 for PC
Adobe photoshop elements (editor) has stopped working
Even though this says Elements 6, it still works for 7. The only difference is the TWAIN file is at: C:Program Files (x86)AdobePhotoshop Elements 7.0Localesen_USPlug-InsImport-Export
Jun 10, 2009 | Adobe Photoshop 6.0 for PC
Editor not working
OK U SHOULD CONTACT THE PRODUCT DEALER BUT ONCE U CHECK THE SYSTEM REQUREMENTS AND CHECK ALL THE COMPONETS ARE THEIR OR NOT IF ANY ONE IS NOT THEIR U SHOULD INSTALL AND IT WILL WORK AND ONE MORE U SHOULD DOWNLOAD THE ADOBE PHOTOSHOP UPDATES U CAN DOWNLOAD FROM HERE ok rate me please 100%
May 25, 2009 | Adobe Photoshop 6.0 for PC
It's most likely incompatible with your system. That's a very old version of Photoshop.
May 10, 2009 | Adobe Photoshop 6.0 for PC
PhotoShop Elements Organizer problem
I am having the same problem, someone please help I have about 4,000
pictures my self
Jan 11, 2009 | Adobe Photoshop Elements 6: Windows
Adobe Photoshop 6.0 for PC Logo
67 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
