Question about Insignia 600W Bridgeable Amplifier with 12" Subwoofer
Protection light i have an amplifier for my car and the protection light stays on and i have check all my wires and connections
    Scholar:
  • 72 Answers
Disconnect one speaker at the time (at the amp) until the protection light goes out, then you know where the problem is.
If your sub is a dual coil wired in parallel and you run it with the amp in bridged mode the impedance will be too low for many amps, seeing it as a short. Then wire the dual coils in series instead or run the coils on one channel each.
I've also seen coils in speakers melt and short out partially, causing too low resistance as seen by the amp.
Posted on May 25, 2009
  • hoboreed20 Mar 01, 2012
    So I know I'm not the one who posted this but I'm having the same issue. I've disconnected both speakers and the red light fades and comes right back on. I've checked my wiring but I'm stuck. How do I know if my subs are dual coil?
Protection light is on all connections are ok
If the protection lights are on it you will need to check the owners manual to figure out why it is in protection mode. The most likely reason is that the power wires are not properly connected. This could be the ground wire not being solidly connected to the vehicle chassis in a paint-free location or it could be the live power wire. Check your connections and connect them all properly. That should fix the problem.
Mar 05, 2011 | Planet Audio VX602 Car Audio Amplifier
Is something wrong with my amp if the protect light stays on or is it the wiring?
It could be the wiring. Sony amps will go into protection if the ohm is to low. They usually like to see 4 ohm or higher. Unplug your speaker wires and see if it still stays in protection. If it does could be an internal thing in the amp. If it isn't rewire subs in series not parallel.
-david
Nov 09, 2010 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Reference 1211a Car Audio Amplifier: stays in protection mode...
Has an internal issue, if you know how to use a ohm meter, check the resistance of the wire on the interior of the amp, also check the fuses, ground, and power wire clean up the ground wire where it is connected to the vehicle
May 16, 2010 | Infinity Reference 1211a Car Audio...
Xplod amp will not get off of power protection mode
if the protect light stays on the amp is blown or has flawed components and is only repairable by expirenced sony tech
May 18, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Amplifier Problem
never ask geeksquad about amps lol check your ground wire connection and push on sub do you feel scratching if so its blown sub also never turn an amp up all the way it starts pushin dc voltage witch a 200 watt amp can blow a 800 watt sub dc voltage is not good for subs also up all the way can burn out the internal battery in the amp lets hope thats not it just make sure ground is good protection light means that the amp has power but a connection is not bien made sum where to complete the circut
Apr 12, 2009 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
My amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Nov 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Amp works when beaten
It sounds like you have a broken connection in the amplifier. The first thing to check is the fuse. Sometimes the contacts become weak on the fuse holder and the connection becomes intermittent. Any other troubleshooting would require opening up the amp. Any repairs would require resoldering the broken connection.
Let me know if you have any other questions.
Sep 22, 2008 | Jensen XA2250 Car Audio Amplifier
Tc 4002 audio car amp
The red light is normal and indicates the amp is powered up. Check your signal wires (RCA patch cords?) and speaker wires. Need more info to be of more help. What receiver are you using? How is it connected to the amp?
Jul 24, 2008 | MTX 4002 Car Audio Amplifier
Nitro 1000 w amp
unplug the speakers and the RCA leads from the amp, if the red protection light is still lit then its 1 of your linear amps blown or mosfet depending what your amp uses..if the red light does go off with the leads all disconnected, then connect 1 lead at a time and check the light,when you connect the bad lead or speaker then the light will come on and you know that 1 needs replacing..hope this helps
Jun 30, 2008 | Nitro BMW-481 Car Audio Amplifier
My amp wont put out sound
it's blown....probably, check your connections and make sure your presenting it an ohm load it can handle....so check the sub with a dmm.
Feb 28, 2006 | Jensen A600HLX Car Audio Amplifier
Open Questions:
Insignia 600W Bridgeable Amplifier with 12" Subwoofer Logo
225 people viewed this question
Top Insignia Car Audio & Video Experts
Mark Skinner
Frank Mangiapane
Level 1 Expert
Are you an Insignia Car Audio and Video Expert? Answer questions, earn points and help others
