Question about Daewoo DV-T8DN VHS VCR
Need replacement belt for play /ff/rewind
Can I buy replacement belts anywhere?
  • Daewoo Master
  • 3,866 Answers
You can try www.zsvideo.com this guy works on these units he may be able to find you a belt for this unit. Thanks
Posted on May 25, 2009
How do I get fast forward & rewinds to work on my Teac W450-R dual cassette deck..?
Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
Jun 07, 2015 | Teac Audio Players & Recorders
Magnavox dv220mw9 the vcr player won't play
Someone will have to open the unit to see what is happening---either tape is not loading all the way or when FF or Rewind hit not moving the reels----could be as simple as a belt or a bad drive idler (most use either a rubber wheel or gears to move the tape in Play, FF, and Rewind.
Dec 03, 2012 | GoVideo VR4940 DVD Player/VCR
Machine will play cassettes but not rewind or ff
Most likely the unit needs new belts. Also possible that a switch has broken. the switched is underthe tape deck on the circuit board.
May 06, 2011 | Panasonic RR-830 Desktop Cassette...
Cassette player doesnt play or record, ff or rewind. CD player, AM/FM radio works fine.
Hi.
If you hear a faint whirring sound from the cassette player while performing these functions, the motor is fine, but you require a new drive belt/s that need to be fitted at an electronics shop. If you hear not sound at all, the motor has died (possibly belts too), again it will require and electrinics repair shop visit.
For the sake of repairing it, it maybe cheaper to buy a new one.
Jan 14, 2011 | Memorex MP3227 Radio/Cassette/CD Boombox
Hi, My Pioneer CTF-7272 Cassette Deck has stopped playing. Rewind works fine, but FF and Play will run for about 5 seconds and then the tape just stops. Any info on this problem is greaty appreciated....
check the belt whether it is broken or loose. if so replace the belt.
I hope this will solve your issue.
Good luck
If my solution proves useful please rank it.
Regards
Arjun.
Mar 27, 2009 | Pioneer CT-W205R Single Dual Cassette Deck
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
Foot pedal
If you cannot play, rewind or fast forward, but you hear a light "click" coming from the cassette compartment, then more than likely you have a broken drive belt, or the circuit controlling the play and/or rewind/ff mechanisms are out. In either case it sounds like you need to send it in or take it somewhere for repair.
Nov 04, 2007 | Dictaphone 2740 Desktop Cassette...
Rewind
Dear Tim, In all likelihood the belts of your VCR have become old and worn. I suggest you unplug the machine, and open the bottom plate. You will now be able to see the Drive belts. Go to a Spare parts shop and buy a Belts set for your nodel from them, and replace. Also, try changing the REW/FF Idler unit. This should do the trick.
Sep 28, 2007 | Panasonic PV-V4524 VCR
Symphonic sc1304, vcr problem
Pulley belt stretched, replace. Remove the back cover to tv, slide the chassis out, remove speaker connector, and other ones to allow the chassis to be out away from cabinet to take the metal cover off surrouding the vcr unit. Usually a couple of screws that hold the whole vcr unit in, remove these, lift the unit from the chassis carefully and check the belt as it is stretched and not making tight grip on the white pulleys that perform the mechanical functions of the VCR. When putting back together, and replaced the belt be sure to lift the vcr door inward before sliding the chassis back into cabinet so the door latch will open and close properly, otherwise you put a tape in and the door won't open back up.
Jun 04, 2007 | Symphonic SC3813 13 in. TV/VCR Combo
Daewoo DV-T8DN VHS VCR Logo
142 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
