Question about IBM Computers & Internet
Hook up to my Samsung 42" plasma TV
I have a IBM notebook. When I hook up the AVG and sound cables to the TV inputs then hit source on the TV no picture it says no signal check cord. The TV is a samsung plasma 42"
  • Frank Zhang
    Frank Zhang May 11, 2010
    whats the AVG and sound cables ? whaTs your laptop port to TV?
  • 105 Answers
Hi There what you need to do is to enable your external vga port this is normally done by pressing your fn ky along with one of the f keys the f key normally has a oblong with a square inside it f4 or f7 seem quite common
If You find this of use please dont forget to leave feedback
Regards AL " Alstech"
Posted on May 25, 2009
Samsung Plasma TV has standby power but no video
Make sure your video and sound cable is working (rca, hdmi cable etc) and your source component like dvd player or settop box is working. If cable is plug into a socket AV 3 or HDMI 3 for e. g. make sure the tv is source or input is selected the same like AV 3 etc.
It is possible for the TV to switch on or off but no picture or sound. This means the input board or tv tuner is faulty in which case you need a good tv repair technician
Oct 26, 2015 | Samsung PN43E450A1FXZA PN43E450 43 720p...
I need a user Manual for a samsung plasma TV 42
if it is anything like mine you have to find the input you connected it to. use the source button on your remote or the source button on the TV . mine is the top button on the right side of the TV when you are facing it. Hope this helps
Jan 06, 2012 | Samsung Televison & Video
How do I connect a dvd player with surround sound?
This depends on how you have it hooked up. You're going to need a Tuner. A simple method is to connect only the Yellow RCA cable (or composite cables) to your T.V. Then connect Red and White RCA cables to the Tuner/Surround sound system you're using on which ever input you're comfortable with. I.E. CD/AUX/TAPE..etc. Change your tuner to that input, and you should get your surround sound through the speakers. Make sure you change the input on your T.V. to what ever video source you got the wires in. If your tuner allows you to hook up a video source to it, you can just hook it up to the tuner and run the DVD player off the tuner only. The first option helps avoid confusion if your tuner isn't set up for any other devices to play video through it.
Jun 24, 2011 | NEC 42VP4 42 in. EDTV-Ready Plasma...
I Have a Samsung HP-R4252 42 in. HDTV Plasma Television and the picture is not showing. It does have sound but no picture. Is there any ease way to fix this problem??
sounds like the video cable is not in the right input.
or maybe you have to redo the setup and be sure the tv is set to the right video input . HDMI or component etc. I hope this helps.
Oct 19, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Tv was on an antenna. Now its hooked directly to cable. Cant get a picture. It keeps saying no signal. Any ideas what to do?
press the button that changes the signal input i.e. AV1,AV2.......until you find the input source for your cable. consult your user manual. Good luck.
Aug 12, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Componet input do not work. Error messages searching for signal,.. no input signal. It is not the source or the cables. Can wiggle the componet inputs on tv and get flash of pix or intermittant. Samsung...
the wiggling of the cables and actually getting a response usually means there is a lose connection/cold solder joint. Narrow the possible connections down and resolder the few solder points or take it to a repair shop.
Jul 21, 2010 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
Samsung TV
PUSH THE SOURCE BUTTON AND SEE IF THE INPUT CHANGES
Dec 20, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Sep 24, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Sansui 42" Palsma
I assume you are saying that the DVD player only has RCA jacks. It would be good to know if the DVD player has Component output as that is the preferred output. You will know this if the RCA jacks on the DVD are color coded green, blue and red.... You would by a set of component cables, hook to DVD matching colors and then find the same color code on input of the TV. You must also run the red and white cable from the DVD output to the TV input for audio. The input on the TV would be labled component in or input and a #. Simply select the input, or source button on remote to select the input that matches your choice and all should function. If there is no component on the DVD output and only a composit hook up (color code by yellow, red, white) again just match that to the corresponding input on the TV.
Jan 06, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Computers & Internet Logo
500 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
