Question about Hobart Welders Champion 500433A Factory Reconditioned 10,000 Watt Generator
Welding breaker keeps popping on my Hobart Champion 10,000.
The breaker for the welder side of the machine keeps popping even when not welding. This machine has about 12 hours of run time and I have never went above 120 amps output or used bigger than a 1/8th" rod.
    Champion:
  • 225 Answers
Look for short inside unit,start at breaker and work your way back.
Posted on Jul 05, 2009
  • hubiam
    hubiam Mar 27, 2017
    Looking for a short and finding one may be 2 separate things. May I suggest you invest in a $10 or $15 analog meter, and two test clips. Connect the pairs of test clips to the opposite ends of the de-energized wire. Set the meter to the lowest ohm setting. Work your way along the wire if the meter's needle moves, then you may have found your short.
  • 52 Answers
Did you put a battery booster on it to start the machine due to a dead battery? If so, that always blows the circuit boards. If you did, look at the board, near a quarter sized red, round think in a corner, and you will probably see a burnt spot on the board in that area.
Posted on Apr 07, 2017
Where is the breaker located? The machine runs but it does not give off power.
Posted on Nov 16, 2009
Hobart welder generator
Sorry we do not have those diagrams.
Oct 31, 2017 | Electrical Supplies
I have a hobart champion 16 and it will barely arc it will not make a weld it went from welding fine to doing this.
Could be something as simple as worn brushes, dirty slip rings, or a bad bridge rectifier. If you know how to check them, these are all something you could fix. If it's anything beyond those, you're best bet would be take it to a repair facility. I repaired welders for 18+ years. (just an FYI)
Jan 04, 2011 | Hobart Welders 500545 Champion Elite 11000...
The F 1 circuit breaker, manual reset is tripping not allowing it to weld. Could it be something as simple as the reset itself
Rated Output at 20% Duty Cycle 150 A at 16 VAC
150 A at 16 VDC Welding Amperage Ranges AC/DC 10 - 165A Max. Open-Circuit Voltage 80 V Amps Input at Rated Output AC-230V: 21A
DC-230V: 23A You need to configure the machine to specifications of the material you going to weld.That is :
-The material of the job
-And the proper amperage to use for the material.
-For aluminum you will use A/C
-Stainless Steele / Chrome Molly D/C
Aluminum MIG Welding
1. The best feeding of wire for aluminum is done with a spool gun. If you can't use a spool gun, use the shortest gun possible and keep the gun as straight as possible. Use Argon only for shielding gas. Only use a push gun technique when welding aluminum. 2. If you are having feeding problems, one thing you can try is a contact tip that is one size bigger than your wire. 3. The most common wire type is ER4043 for all-purpose work. ER5356 is a stiffer wire (easier to feed), and is used when more rigid, higher-strength weld properties are needed. 4. Clean the aluminum before welding, to remove the oxide layer. Use a stainless steel wire brush used only for cleaning aluminum. 5. Fill the crater at the end of the weld to avoid a crack. One way to do this is to dwell in the weld pool for a second at the end of the weld.
Nov 07, 2010 | Hobart Welders 500433 Champion? 10,000...
Where can i get parts for my hobart welding machine but is a old welder
Your local welding shop supply will be able to give you advice, the guys at Lowes and farm supply shops just sell the welders
Oct 05, 2010 | Hobart Handler 125 115 Volt 30 To 125 Amp...
I pluged it in and it popped?
Check welding supply shops that sell Hobart welders.
Apr 08, 2010 | Hobart Handler 125 Ez
I have a Hobart Champion 10,000 welder generator. It runs but I am getting no juice out of it. Won't weld or put out power to run anything.
measure ouput on ALL available sockets - anything?
Take cover off electric motor-generator, visually inspect windings.
Measure continuity of all stator windings (2 or 3 points usually)
Measure continuity of stator thru brushset.
If all measures ok - has to be AVR module.
There is no mistery in generator - just stator to induce and rotor to obtain voltage.
Jan 01, 2010 | Hobart Champion 10,000 All-in-One...
Not generating power
The engine is not running the welding transformer. It may be a fuse, drive belt or gear wheel. Or the transformer is shorting out. Check these points in this order if the last one maybe you will have to replace the transformer. The transformer is 2 coils to stop them shorting out where normal electric wire is cover in plastic or rubber the coils are coated with enamel as are sum cooking pans. If this is damaged in any way it will short.
Apr 08, 2009 | Hobart Welders 500433 Champion? 10,000...
Welder will not power auxillary outlets
sounds like either something is shorted out or the governor is stuck. Check the governor linkage to start with and make sure it is free. Then check the push in breakers for the outlets to see if they are popped. If not the brushes or the armature could be stuck or corroded.
Mar 28, 2009 | Hobart Welders 500433 Champion? 10,000...
Won't idle down between welding
have you went to your local welding store? Praxair or airgas can call Hobart for the part you request,or they will call their Hobart salesman for you.
Mar 08, 2009 | Hobart Welders Champion 500433A Factory...
Hobart Welders Champion 500433A Factory Reconditioned 10,000 Watt Generator Logo
1,473 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
oneStan
oneStan
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
