Question about Hypertec Phoenix 370/S (HYPH01) Motherboard
Problem with bios settings
I changed a setting in the bios setup and now i cant get back into the setup screen it says press delete to enter setup but it does nothing, cant remember the setting i changed but it starts with an f i think , i was having a problem getting windows 2000 pro to boot up so i was trying to change some settings to see if i could get it to work. if i could just get back into the setup menu to change the setting back i think i can fix the problem now. i have a matsonic ms-9377c motherboard and phoenix award workstation bios v6.00pg if that helps. i cant for the life of me remember the setting i changed but i think it was next an option to optimize settings. any help would be appreciated thanx
  • jlong1664 May 25, 2009
    thanx guys i figured it out after i screwed with it for four hours, moving the jumper fixed the problem like you said. thanx again
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    On your motherboard see if there is a jumper to clear the bios if it is then clear it by moving the jumper. Then turn the computer back on and try going into the bios.
  • 2,404 Answers
So moving the jumper to clear the BIOS did help? Excellent, please rate me on my solution when you get the chance.
Posted on May 25, 2009
  • 3,866 Answers
Okay this is a craps shoot but you need to move the jumper on the battery to set this bios back at defualts on the motherboard. This will let you in by force and that way you can change back what got hosed..
How to use a usb keyboard
as a P/S2 keyboard.plug it in the USB contact in the back.in any USB port.
Apr 08, 2013 | Dell Inspiron One 2305 Desktop Computer...
Tip
How to Fix NTLDR is MISSING
1. Locate you Windows XP CD and place it in your CD-ROM drive.
2. Restart your computer, or turn it off and then back on.
How to fix NTDLR MISSING error.
3. When you computer restarts you should eventually see the words "Press Any Key to enter Setup". If you do not see these words and it goes to the screen that gives you the error message, you will have to change your boot priority in your bios settings.
Changing boot device priority:
A. When you see you’re the first screen, the boot screen, press delete a few times until your computer beeps. Pressing the delete key will bring your computer up into the bios settings. The key you need to press may differ from computer to computer. If the delete key doesn't work for you, contact your computer manufacturer and ask them what key you need to press to get into bios.
B. After you are in your bios settings you will need to navigate to your boot settings. Depending on which type and version of BIOS you have, this process may be different. Either way, there should be a section called Boot or Boot Priority. Navigate to that and make sure that your CD-ROM has top or first priority. After you have don't that, save and exit (press F10).
4. Once you see the "Press Any Key to Enter Setup" message, go ahead and press any key.
5. This will start the Windows Setup Process; it will take it several minutes to load.
on Feb 04, 2009 | Microsoft Windows Vista Ultimate Edition
Keyboad failure on dell gx520 boot
Usb or Ps2 keyboard ?
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Enter bios restart your computer you will see a certain to press to enter set up usually the Delete or the F2 key this will vary depending on you computer and bios. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Enable PS2 & USB in BIOS You can enable PS2 and USB settings in BIOS by entering the BIOS setup screen when the computer boots. You will need to changes to the appropriate settings in this screen. The exact procedures vary by system, but there are a few common methods that may work if the motherboard manual is not available for guidance. The general procedure is the same for any modern computer system, but the menu arrangement and keystrokes to enter the setup program can vary greatly from one machine to the next. Power on or restart the computer and watch the initial boot screen to find the keystroke required to enter BIOS setup. This is often shown at the bottom of the screen. Typical keystrokes include pressing the "F1," "F2," "F9," "F10" or "Del" key. Press this key when the prompt appears on the screen. You can find the proper key in the computer's motherboard manual or on the website of the motherboard or computer manufacturer. Enter the BIOS setup screen and look for the "Advanced" or "Onboard Device Configuration" menu. Use the arrows to select your choice and press "Enter." Change the settings for the PS2 port by moving the menu choice to the "PS2" setting. Press "Enter" to bring up a smaller menu with the options to enable or disable the PS2 ports. Select "Enabled." You can also use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the PS2 port. Change the settings for the USB port by moving the menu choice to the "USB" setting. Press "Enter" to bring up a smaller menu with options to enable or disable the USB ports. Select "Enabled." Alternatively, use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the USB port. Save the settings and exit by pressing "F10" or using the "Esc" key to back out of the current menu. Choose to save and exit from the main menu if needed. Follow any additional instructions on the screen to save or navigate the menus. Hope this helps.
Dec 13, 2012 | Dell OptiPlex GX520 PC Desktop
I cant get into setup when starting up computer it is a presario sr 1000 desktop
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS
the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
or
using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Jul 29, 2012 | Compaq Computers & Internet
Can't boot from sata CD drive to set up windows xp
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you should go back and change the settings to failsafe or optimised defaults) this will change the first boot device to floppy
hope this helps
Aug 03, 2011 | ASUS P5RD1-VM Motherboard
Cmos checksum bad
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
Diagnosis: The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
don't forget to vote
Feb 11, 2011 | Computers & Internet
Coms setting wrong plz detail rightbios seting in all
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Jan 26, 2011 | Mercury P4VM800M7 Motherboard
Actual problem is that i forgot my windows xp login password. how can i solve my problem? and another problem is that when ever i inserted any bootable cd in cd-rom it displayed compaq logo only. how...
During the boot up process you will see on the screen press delete to enter set up
Press delete during the boot up process to enter BIOS scroll down to set user password or administrator password you can change or remove your password from there
hope this helps
Oct 26, 2010 | Compaq Presario 2100 and 2500 ,NX 9000...
How can i set first boot drive on an IBM PC, model is FRU PN 02R4087
Hi van Carlisle,
you will have to go into BIOS during the startup, I am not familiar with the FRU PN 02R4087 but the process is more or less the same for all PCs.
When you start your PC watch the screen carefully, at one point there will come a text similar to "to enter setup press Delete" usually it is either the Delete key or F2 or F10... watch your screen to find out which key is for the setup on your computer. you may have to start many times over before you get everything.
Once you have entered BIOS you will have to look for a page that contains an entry like "First Boot Device" or something similar. it should be set to HHD1 or CDROM or Disk... then follow the directions on how to change this value to what ever it is that you wish. Be Aware that there are other options in BIOS that in changing them you can quite possibly damage your computer, so do not change anything else unless you know what you are doing.
I hope I was able to help you on this.
Oct 21, 2010 | Computers & Internet
Hypertec Phoenix 370/S (HYPH01) Motherboard Logo
175 people viewed this question
Top Hypertec Computers & Internet Experts
David Payne
David Payne
Are you a Hypertec Computer and Internet Expert? Answer questions, earn points and help others
