Question about Fedders A6Q10F2B Q Chassis Room Air Conditioner
Constantly running compressor runs all the time even if the unit is turned off or on fan mode the coils are freezing up but no way of shutting the compressor off
  • russell boisseau Apr 27, 2012
    yes the compressor will run constant no matter what mode you have it in and even if you push the power off button everything else will turn off but the compressor will continue to run and the only way to get the compressor not to run is unplug it at the receptical
  • 116 Answers
Follow the wires from compressor to contactor or relay contacts stuck replace
Posted on May 25, 2009
I just bought a usedwhirlpool it runs all the time it never cuts off is it suposed to do that
It should shut off after satisfying the thermostat control setting. The control could be bad or the refrigerator is not cooling enough. Check to see if the coils under the refrigerator are not blocked with lint and the fan by the compressor in back is turning. Also check if the fan blade is not dirty with lint. These things could cause the refrigerator to run constantly.
May 17, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kelvinator fridge compressor running constantly, but freezer section barely freezing
CHECK THE CONDENSER COILS UNDER THE UNIT. THEY PROBABLY ARE DIRTY AND CANT REJECT THE HEAT.
Oct 18, 2012 | Kelvinator Refrigerators
Why does the fan run non stop? the compressor runs and shuts off but the fan just runs on high and low. I have 3 other dehumidifiers that the fan runs only when the compressor runs...why doesnt the...
Depending on the time sequence you have this unit set to run, Fredrich's are designed so that the fan runs almost constantly, to keep the air moving. When it senses a rise in humidity above the level you have it set on, the compressor turns ON and runs until the level of humidity is lowered. This is especially true, if you are operating this unit in continual mode.
Hope this helps you and thanks for choosing FixYa.
Aug 14, 2011 | Friedrich D50C Dehumidifier
Just purchased a Danby dehumidifier (model # DDR6O11R). I was wondering when the dehumidifier reaches the programmed level of humidity (example: 40%). Is the unit suppose to shut off completely? I believe...
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
Hope this helped you. Please let me know. Thanks.
Jun 06, 2011 | Danby Dehumidifier
I have a tfx22zr and the door seals are warm to slightly hot at times. The fridge will not stay cold to the point of food spoiling at times. the freezer gets to the mushy freeze mode. I emptied both and...
One of two things either the condenser is dirty,that would be the black coil under the refrigerator,or the condenser fan motor is not running,that would be behind the refrigerator at the bottom behind the panel,at any time the compressor is running this fan should be running,if it is not,the compressor will run and cool somewhat but overheat often and cycle off causing fluctuating temperatures,the motor is easy to change and fairly easy to find on most GE units....hope this helps
Sep 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a beverage air kegerator that seems to work fine, but the evaporator fan runs constantly. Is it supposed to run constantly, or is it supposed to cycle on and off with the compressor, etc.?
Most evaporator fans run all the time. This is mainly to use the air flow to assist in melting off any frost build up during the compressor off cycle. If that fan shut off with the compressor the coil will have a tendency to freeze up. :)
Aug 13, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Year 2005 cycling fan and compressor
Your unit is probably operating in defrost mode. When you use a dehumidifier in a cold room, the condensing coils can freeze water. The unit senses this and thus stops the compressor until the water frozen on the coils melts. Then it resumes its cycle. This is a problem you will have during the winter months. It makes the operation of the unit inefficient, but this is otherwise normal behavior.
Jan 04, 2009 | LG LD50EL Dehumidifier
Freezer/refrigerator compressor running constantly
th ebi-metal is a thermostat which shuts the defrost heater on/off, but doesnt actually put the unit into defrost. if it were bad the defrost heater would never go on resulting in massive build up of ice on back wall of freezer, and noticable refrigeration sect. cooling.. dont know how you know the compressor never shuts down, but if that the case perhaps you have a sealed system/ freon issue. try removing the back panel of freezer section and check the evaporator coil. you shuld have an even frost pattern over the entire evap coil. if theres just frost over the top 1or 2 coils, and the rest of coil is shiny aluminum , thats an indication of a sealed system issue.( 5 year part warr by manufacture) def not a do it yourself issue...but that would,, depending on extent of restriction/loss of freon,, cause freezer to freeze and defrost eratically,and the compressor would be running constantly trying to achieve a good stable temp
Apr 02, 2008 | Refrigerators
Constantly running
If the thermistor sensor for the temperature control is going out that could cause the compressor the think it needs to keep running to cool the unit. The fan near the compressor should run only when the compressor runs. If the fan is running and the compressor isn't then you likely have a compressor start device problem or the overload is tripping from high heat, etc. That would make the compressor run (or try to) every minute or two if not just run continuously. Make sure all the coils under the unit are clean of fuzzy's and hair, etc. by doing a good vac. clean on them also. The compressor can be slightly warm to the touch but shouldn't be so hot that it is hard to keep you r hands on it for long. If it's around 130 degrees F, then it may be the start device problem and is in an overheat condition.
Dec 09, 2006 | Roper RT21AKXKQ Top Freezer Refrigerator
Fedders A6Q10F2B Q Chassis Room Air Conditioner Logo
288 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
