Question about Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher
Dishlex Global Unable to remove heater element retaining screw
Have a Dishlex 300 and we are unable to remove the stainless steel retaining screw so the haeating element can be removed.
Does any one have any ideas
  • Anonymous Mar 23, 2014
    Heater not working
I have a simialar problem with the Dishlex 450 Global model, after searching for the heating element on line, I found a picture of the element (450 model), showing that the Stainless Steel screw is actually spot welded to the element bracket, hence you should be able to remove it by accessing a retaining nut from underneath the dishwasher....(turn power off first!)..
Posted on Jun 10, 2009
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Jan 25, 2010 | Dishwashers
The dishlex 302SB is not producing hot water for the washing
I have a Dishlex 302 which had this fault. Initially I thought it was the inline heater element and replaced it. It seemed to work but later no hot water again. Someone here put me on to the problem. There is a dry joint in the control board in the top of the door. This controls the relay which powers up the heater. Unplug it from the mains (very important) and undo the screws around the top of the door (don't take the door right off!) you will be able to wiggle off the front panel containing the electronics. The control board is ealiy disconnected an removed from the machine in its protective plastic cover. Have a look around the PCB and you will see the dry joint. Resolder with rosin core (electronic) solder, reassemble and you should have hot water.
May 23, 2009 | Electrolux 504199 Dishwasher
Pump motor runs continuously, ''Eco'' flashes continuously
Hi
soyunds like it flooded the base
You need to dry out the base of the machine thoroughly and it should re set
Feb 14, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Replace bottom door seal on Dishlex Global 300 Dishwasher - Model DX300SA
HI - i just replaced the bottom seal yesterday. The guy at the spares shop advised me to replace both (bottom of door and bigger seal ) at the same time to ensure no leaks - i did that. The bottom door seal come out when you unscrew the screws - (No need to remove door) and because of all the gunk (from years of washing and age of the rubber) i had to wedge a blunt knife in between (starting at one of the ends) and lever it out - MAKE SURE YOU TAKE NOTE OF THE WAY IT IS BEFORE YOU REMOVE IT! An easy way to remember is there is a nick in the rubber of the old (and new) seal and as it is not centred, just note if the nick is closer to the left or right of the machine, I have replaced mine and there is a little leak and now i wonder if i put the seal in upside down! it has to go in the same way - before you gimmy your's out can you tell me if the nick in the rubber is to the left or right? (LIZ at yodelayeeoo@gmail.com) If I have put in back right there is a chance the screw didn't go through the plastic part of the seal and therefore not holding it in place properly. GOOD LUCK! Don't worry about having to really work at getting the old seal out - you don't need it anymore and i didn't damage mine, regards, Liz
Jun 15, 2008 | Dishwashers
Removal of pump casing
You Can Remove it with a screw driver,put a small flat head screw driver in the slot to the right and push to the left to unlock catch on bottom and pull up on unit.
Dec 24, 2006 | Kenmore 15073 Stainless Steel Built-in...
Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher Logo
1,234 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
