Question about Karcher Garden
Karcher k3.98 pressure washer not holding good presure
I check it took it apart and found that where the detergent feeds into the machine is crack is this fixable or is my unit shot?
  • apat Apr 22, 2013
    very nice explaination by svoegele2, thanks i have a question on this, i have hairline crack at the same place( on housing of soap inlet valve), my question is if i dont wnats to use the soap despenser any more, can i just fill the soap valve housing with some hard material (like bondo) and just use my machine as washer only. so that way i dont have to buy a new upper housing. is it doable or itis required to be open for proper functioning of p. washer. thanks in advance
  • 92 Answers
Dear svoegele2,
Your machine is still good. You have to remove the 4 screws that are holding the head unit. The head unit consists of 2 parts. The outer part has Intake of water and delivery of water under pressure. It has an injector. It also has the chemical inlet attachment. This Detergent inlet valve can be replaced by a new one. (The bottom part of the head has the suction and delivery valves.)
Now this unit of 2 heads is held down with a steel cover. First release the holding down bolts( they could be allen screws or Torx Screws). If the inlet valve for the chemical is still good and t is turned 90 dgrees, twist it slowly to be alligned with the slot in the metal cover. But if this is broken, just remove the metal head and then remove by twisting,..the detergent inlet..(which is also a non return valve).
Carfull if you seperate the top half of the head from the bottom head...because underneath there is a smal spring and a small valve. Do not lose these.
Now if the machine has no pressure..change the bottom half of the head. If the machine is switching on and off...change the upper half f the head. Do not forget that small spring between the 2 heads If where the inlet for detergent in the head is cracked..this top head must be renewed for this reason also.
If all is OK...but only the inlet..where the detergent is broken....remove slowly the detergent inlet, by twisting a little,....and replace by a new one. First see that you have the NEW inlet of detergent before doing anything . Because if you do not find to buy a new on....and there is no damage to the upper head...you can continue using the machine,...but with out having detergent. It is better using it without detergent than throwing the machine away. One final hint. Try the machine with the plastic cover removed,..so to see if there are any leaks or cracks in the head unit.(wear safety gogles). If only the inlet for detergent is broken and no water is escaping from it or the head,...buy a new inlet detergent valve. If you do without detergent and you cannot find to buy a detergent inlet valve,...just close the machine and use it without detergent. When myself I service such machines...I change the whole head unit and detergent valve. Then the machine will be as good as new. And the spares are not that expensive. Better than buying another machine.
Regards,
Fulltech.
Posted on May 25, 2009
Water coming out of detergent pipe from top for karcher 3030 b jet wash
DISCONNECT HYDRO OR WITH ENGINE NOT RUNNING DISCONNECT SPARK PLUG THEN RE-LEAVE WATER PRESSURE BEFORE SERVICING the detergent pipe plugs into a pipe on the pump, under which is a spring and ball bearing (stuck open, debris) WEAR YOUR SAFETY GLASSES
Apr 01, 2014 | Karcher Garden
Karcher will not **** up detergent
onl use low pressure nozzels to pick up detergent, high pressure creats too much bck pressure
Mar 29, 2014 | Karcher Garden
2600 PSI Pressure washer will not draw detergent up
I posted an answer to no soap on the Karcher Factory-Reconditioned 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR. Same machine I suppose, but use the black 65 l degree low pressure nozzle.
It's in the manual , I missed it and had a hell of a time trying to figure it out. If that doesn't work check the check valve on the pump(Where the soap hose is) , see if it's gummed up.
Be careful taking it off there's a spring and ball bearing in there.
Apr 09, 2013 | Karcher Garden
I have karcher k4.98. I can not get the detergent to come out. I have checked the trouble shoot in the manual and all items are ok. Any ideas ?
Just had the same problem, brand new machine, the detergent feed pipe was squashed under the bottle holder bracket!
Dec 30, 2012 | Karcher Garden
I have a Karcher K3.540 pressure washer. Won't take up detergent and motor pulses ever second if vari-lance increased towards maximim. Motor runs ok at lower pressure but can take 1min to start wh
This fault is within the control head, under the detergent valve is a small spring loaded valve that acts to induce the detergent, this will have failed, the shaft of the component breaks off the disk base leaving a small hole in the centre of the disk. This is enough to allow pressure past the component. The machine will pulse when operated and will not induce the detergent. I've looked everywhere to find this part as I have a karcher with the same fault.
Jan 22, 2012 | Karcher Garden
Presure relief value not working when let off trigger on wand
sounds exactly like the problem and the soluition you are looking for.
Mar 12, 2010 | Karcher 2500 PSI Pressure Washer
Craftsman pressure washer #580761810 will not dispense detergent.
Karchers are known as one shot wonders, The pump used on them is an aluminum alloy that powders when you use any type of chlorine/bleach detergent in them at all. My advice is to use it as just a pressure washer and spray the detergent with a hand pump garden sprayer. The pump and parts are so expensive that its not worth the time or money to try to repair. I also feel that if you are not a monthly user of this machine it is much more cost effecient to rent one for the day when you need one.A reputible rental price is about 30 dollars for 4 hours or 50 for 24 hours.Good luck
Nov 03, 2009 | Karcher 2500 PSI Pressure Washer
Water keeps popping off t he detergent cap.. even though water is not even hook up.. guess it is detergent popping out .. what is wrong with it.. cleaning fitting is not even on
detergent non return valve stuck, allowing water to back feed into the chemical tank.
depends on what machine it is as to where the non return valve is.
Jul 17, 2009 | Karcher Garden
Karcher pistol gun has broken
i do not think there is a pressure release valve , sounds like the plastic inside the pistol has become brittle and has failed under pressure , you dont say how old the pistols are ? and if you run strong detergents through them .
May 26, 2009 | Karcher PSI Electric Pressure Washer
Karcher k4.98 switching on and off
The machine has a pressure leak. Check for a cracked controll head or either a leaking outlet elbow. The machine will short cycle if the holding pressure can not be maintained
Feb 19, 2009 | Karcher K2.26 Electric Power Washer
Garden Logo
1,595 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
