Question about Epson Office Equipment & Supplies
My printer will not print from the computer
It will copy, scan, etc but will not print from the computer. Has new ink, but it will not print a test page.
    Sergeant:
    Champion:
  • 240 Answers
Its a printer driver issue for me..
I think you need to reinstall your printer driver again..
first you need to uninstall existing printer driver ..and restart your computer ...and then reinstall you printer driver..
why you need to reinstall?
because the printing application for the printer has been corrupt or missing..only the copy and scan application is running properly..
that's why it only scan and copy..but not print some document..
thanks for using FIXYA...
Have a good DAy..ahead^_^
Posted on May 25, 2009
I just want to print - computer says it is "off-line'. Print says "scan, copy, etc." but not 'print'. What do I do?
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken .Use the test print to calbrate the SCANNER.
Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Sep 02, 2011 | HP C4680 All-In-One Inkjet Printer
Blue Color On Copies
Check your settings for copying through your printer software.You might have accidentally messed up some copy settings there (Contrast, etc.)
Rollers do not have anything to do with this because your regular prints and copy prints are fed through the same roller.
Try removing your printer from Device Manager. Completely remove your printer software and reinstall all this stuff like you're installing a brand new printer. There is a 90% chance that your printer will be find after this.
Hope that helps.
Feb 19, 2010 | HP Officejet K60xi-Printer/Fax/Copy/Scan -...
Cannon pixma mp750 - it is telling me "waste ink near full" but i can't find any mention of it in the guide etc. It is not printing at all. Can you help?
Just another little way that Canon have found to get more money from you, would probably cost you at least $150 for Canon to fix, but you can, I think this should work.
Reset Waste Ink
1) Enter SERVICE MODE.
By pressing Menu, Copy, Scan, Copy, Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Jul 05, 2008 | Canon Office Equipment & Supplies
Hp psc 950ink cartridge alignment
In my experience, the <align cartridge> happens when you change ink, has a [don't do {HP chat would be a help}] and wouldn't let you print or scan either unless completed.
normally prints a [2] sheet, then asks to scan it.
for photo quality, override isn't reccommended.
does copy work at all?
scan, save, print might work
Jun 09, 2008 | HP PSC 950 All-In-One InkJet Printer
Waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
Mar 01, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Black ink does not print
I have a problem about my printer here. it doesnt print black color even if i replaced it with new cartridge...anyone have solution about this pls help....joy
Feb 16, 2008 | HP Photosmart C3150 Printer
Printer will not print- blank returns
make sure carts are placed well and secured.
press menu then start bk copy then four times arrow-up (tel. index). machine switches to maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink in tubes and ph and do some cleaning. after that press 7 then 6 then 3 then start bk copy. machine will do a power purge. after that leave mode by pressing 9 then 9. Run a quality test print by pressing ink etc.
If you still cant see any colors the ph has dryed out. If you see some blocks try a manual cleaning (pressing ink shift to cleaning etc.). If the next test print out still is bad the ph is clogged due to generic ink and cant be cleaned anymore. In both way ph needs replacement.
Dec 08, 2007 | Brother MFC 420CN All-In-One InkJet...
WILL NOT COPY
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
Sep 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
212 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
